Loading problem of product in the assembly
When I open a particular assembly, some of the products shows that some children are missing. But, that files are available in the folder. When open that products individually, that children are viewable. So, to correct the problem in main assembly, I opened the product first and then open the main assembly which gives everything fine. To correct this problem, I tried the load option by right clicking the product in the assembly. But, the message comes that it is already loaded. Kindly give any idea to enable that children in the main assembly itself.
Suresh
RE: Loading problem of product in the assembly
Are you facing this issue in stand alone CATIA or with PLM integrated environment??
I have also faced the same issue in CATIA while working with TeamCenter(PLM) integrated environment
Hi Sachin,
I am facing this problem in stand alone CATIA.
Suresh
