Vis Professional vs. Mockup
3
Hi folks,
I'm very familiar with Vis Mockup having used it in several previous roles. My current employer is looking to invest in a supplier integration package comprising Tc and Vis Professional. I'm not so familiar with Vis Pro, what features does it lack in comparison to Mockup?
Thanks!
RE: Vis Professional vs. Mockup
Hi Dave,
I have worked on mock-up only but not professional. However to my understanding these are the plus for Mock-up.
(1) Mock-up contains Motion Playback enabling detection of interference dynamically.
(2) Neutral file support including VRML and STL ,STEP,IGES and DXF.
(3) Clearance analysis tools (static and dynamic) are more extensive
(4) Advance filtering capabilities that enable search on part attributes and properties to control geometry displays.
(5) Volume clipping inside/Outside of a cuboid.
Offcourse there can be some more but i am aware of these only.
Would be good some expert elucidating on the same.
Best Regards
Kapil
Here's a cut & paste from the descriptions we have access to:
In additional to the features included with a Teamcenter user license, Teamcenter Visualization Standard service level includes:
- Visualize part and assembly properties and layer information
- Visualize PMI
- Advanced 3D visualization tools, including part selection, dynamic highlighting, part visibility control, and user-defined views
- Advanced 3D measurement
- 3D markup tools that can include URLs and 3D geometric dimensioning and tolerancing (GD&T) symbols
- Direct read of VRML and STL files
- Explore navigation mode
- Snapshots
- Image capture
- Send email
- Enhanced 3D session and conferencing
In additional to the features in the Standard service level, Teamcenter Visualization Professional service level includes:
- 3D comparison
- Dynamic 3D cross-sectioning
- CAE results viewing (JT format)
- Callout and Symbol Manager for annotating illustrations
- Thrustline Editor for creating exploded view centerlines
- Outline Capture including hidden-line removal
- Precise transformation
- Manipulators for interactive translation, rotation and scaling
- Appearance editor
- Fly navigation mode
- Exploded View
- Motion file playback (VFM files)
- Support for stereo viewing
- Stereo Viewing
- Export JT (including alternate hierarchies), VRML, Nastran, and PLM XML files
- Create session packages
- Animation file playback
In additional to the features in the Professional service level, Teamcenter Visualization Mockup service level includes:
- Neutral-file support, includes VRML and STL.
- Read of STEP, IGES, and DXF with associated optional JT translators
- Extensive static and dynamic clearance analysis tools
- Advanced attribute and property filtering to control geometry displays
- Volume clipping either inside or outside of a cuboid
- Extensive geometry editing tools Including re-tesselation, decimation and creation of shrink-wrap volumes
- Motion capture for output to appropriate movie formats
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
