"knurling" on stainless steel
any tips on how this kind of "knurling" was made on this stainless steel pipe?
1) pipe was not deformed during this proces
2) it is not additionaly welded (however it looks like this) - this surface is "torned out" from pipe material
3) anyone knows machines which can do this type of surface ? (if not - I need to do some R&D'ing on my own)
thanks in advance
M
thanks in advance
M
RE: "knurling" on stainless steel
It also looks like a bit like a very heavy spark eroded finish.
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
or corrosion in some aggressive environment.
Wait; you _want_ a surface like that?
Be aware that it may have greatly reduced fatigue resistance, not ordinarily a desirable thing in pipe or anything else.
Mike Halloran
Pembroke Pines, FL, USA
http://www.slipnot.com/products/ladder-rungs/stain...
Mike Halloran
this is the purpose, it is used in chairs as a shoes slip-protector
but it is made only on a small part of pipe, not fully around
thanks for a link to this ladder company
https://en.m.wikipedia.org/wiki/Thermal_spraying
B.E.
You are judged not by what you know, but by what you can do.
The surface appears to have small nodules of material. I can't think of a material removal process that creates this type of shape. Though I'm not familiar with spark erosion or many plasma techniques.
I don't see much regularity/pattern in the textured surface. Therefore I suspect it's not an embossed or rolled surface.
Some kind of deposition might make that sort of texture, and could be done on only part of the surface.
As for chemical etching, the boundary between polished and textured surface is not a nice line that I would expect if you masked and etched.
Another clue is shown on the edge of the textured-polished boundary. There appear to be voids there. It looks to me like the high points in this area are ground and/or polished down, leaving only the low spots. Material deposition on one side followed by grinding/polishing could do this.
Is there much variation in thickness on the polished side vs. the textured side?
Mike Halloran
this surface is a desired surface - I mean manufacturer wanted to do that and he did it nice way
this is of course a new pipe and material is homogenous
see attachment for an evidence
