pickup to pc - is the latest trend in vibration analysis and data collection?
I recently came across this.
http://www.sequoia.it/en/fast_tracer.htm
They claim
FastTracer can be connected directly to the PC’s USB port and associates a triaxial value in the time and/or frequency domain of the vibrations of the machine being analysed with each measurement point.
Is this true? If anyone has any experience with this type of vibration analysis and data collection, your feedback will be much appreciated. Thanks.
A pdf of their specs is also attached here.
Muthu
www.edison.co.in
RE: pickup to pc - is the latest trend in vibration analysis and data collection?
Thanks IRstuff.
Are they accurate and reliable for measuring large motor/generator vibrations?
Could you please let me know the other OEM's that use this technology?
Muthu
www.edison.co.in
Any country of origin is fine with me. As long as it has been proven to be trustworthy. I am thinking of upgrading from my old swedish hand held model analyzer.
Muthu
www.edison.co.in
Thanks IRstuff.
That stuff still requires an interface between the pickup and the pc?
Muthu
www.edison.co.in
Sure, unless the PC has built-in I2C or SPI. Note that you'd also need a breakout board for the accel and its required connections.
But, Digikey sells the accel for under a couple of bucks, and you can probably get a USB-based Arduino or similar that supports SPI/I2C.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Thanks IRstuff. I am not competent to build a system. Just an end user here and this new method of pickup to pc seemed novel and simple to me. I am in touch with the OEM but still not convinced about how their sensor, which is 55x30 mm rectangle base, can be fixed on to the curved motor surfaces given the large foot print.
Muthu
www.edison.co.in
