Frost Protection on AHU Unit with Plate Heat Exchanger Heat Recovery
I am designing a 100%OA system where frost protection (35%glycol) will be running through heating coil (AHU unit has Plate heat exchanger). Winter outdoor temperature is -7 C. My question is what temperature I need to bring the air at the heating coil to avoid any damage on the coil? There are also reheat coils at each zone.
Any design suggestion??
RE: Frost Protection on AHU Unit with Plate Heat Exchanger Heat Recovery
I'd like to know what temperature I need to bring the outside air to. I think I have to heat outside air up to 55F but I saw someone was saying it should be enough to bring outside air to +5 C (41 F) somewhere in the forum. Is there a common application/rule for this temperature? Regards
Look at ASHRAE it has LAT calculations formula - if you still can't find it, then we will. It is easy to give you the answer, but I think you should be able to dig it easily so you can remember it.
Use a condensate drain for the wheel, and don't forget to heat trace it.
Locate you pre-heat coil upstream of wheel.
Thanks for the tips!
