Recommendation for Infrared Transmitting resin
Gentleman hello,
I would like your help to define an Infrared Transmitting resin for a part i am designing, the part is a cover (see attached picture) for an IR transmitter, the cover snaps into a designated opening in some other part.
Manufacturing method: Injection molding.
Material properties: Infrared Transmitting resin for 850NM wave length, not very rigid for snap features to work well.
Color: Black.
Thanks for your help.
Color: Black.
RE: Recommendation for Infrared Transmitting resin
It's quite stiff with a low elongation before break so you will have to do the sums for your snap fit cantilevers.
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
