Hole Edit Journal, NX9
I've made a template file with a hole feature. It's always Feature (26)
I want to be able to switch it from Cbore to Csink to Simple.
The Journals I've made do it well in the seed file. But after cloning it into an assembly it doesn't work.
I'm sure it's because it's not the same file anymore.
How can I make this universal to any file with this feature?
TIA for any help
' NX 9.0.2.5
' Journal created by Dave on Tue Oct 27 06:06:17 2015 Eastern Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Feature Parameters")
Dim holePackage1 As Features.HolePackage = CType(workPart.Features.FindObject("COUNTERBORED SCREW HOLE(26)"), Features.HolePackage)
Try
' Invalid feature.
holePackage1.SetGroupActive(True)
Catch ex As NXException
ex.AssertErrorCode(670060)
End Try
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start")
If Not workPart.Preferences.Modeling.GetHistoryMode Then
Throw(New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
Dim holePackageBuilder1 As Features.HolePackageBuilder
holePackageBuilder1 = workPart.Features.CreateHolePackageBuilder(holePackage1)
holePackageBuilder1.StartHoleData.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Subtract
Dim targetBodies1(0) As Body
Dim nullBody As Body = Nothing
targetBodies1(0) = nullBody
holePackageBuilder1.StartHoleData.BooleanOperation.SetTargetBodies(targetBodies1)
holePackageBuilder1.MiddleHoleData.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Subtract
Dim targetBodies2(-1) As Body
holePackageBuilder1.MiddleHoleData.BooleanOperation.SetTargetBodies(targetBodies2)
holePackageBuilder1.EndHoleData.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Subtract
Dim targetBodies3(0) As Body
targetBodies3(0) = nullBody
holePackageBuilder1.EndHoleData.BooleanOperation.SetTargetBodies(targetBodies3)
Dim targetBodies4(0) As Body
Dim body1 As Body = CType(workPart.Bodies.FindObject("EXTRUDE(3)"), Body)
targetBodies4(0) = body1
holePackageBuilder1.BooleanOperation.SetTargetBodies(targetBodies4)
holePackageBuilder1.HolePosition.PrepareMappingData()
holePackageBuilder1.ScrewClearanceHoleForm = Features.HolePackageBuilder.HoleForms.Counterbored
theSession.SetUndoMarkName(markId2, "Hole Dialog")
holePackageBuilder1.HolePosition.DistanceTolerance = 0.0004
holePackageBuilder1.HolePosition.ChainingTolerance = 0.00038
holePackageBuilder1.ScrewClearanceHoleForm = Features.HolePackageBuilder.HoleForms.Countersink
holePackageBuilder1.ScrewClearanceCountersinkDiameter.RightHandSide = "0.762"
holePackageBuilder1.ScrewClearanceReliefDepth.RightHandSide = "0.06"
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Hole")
theSession.DeleteUndoMark(markId3, Nothing)
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Hole")
holePackageBuilder1.ScrewType = "Machine (82 degree)"
holePackageBuilder1.StartHoleData.ScrewType = "Socket Head, 4762"
holePackageBuilder1.StartHoleData.ScrewSize = "M1.6"
holePackageBuilder1.StartHoleData.FitOption = "Close (H12)"
holePackageBuilder1.MiddleHoleData.FitOption = "Close (H12)"
holePackageBuilder1.EndHoleData.FitOption = "Close (H12)"
Dim nXObject1 As NXObject
nXObject1 = holePackageBuilder1.Commit()
theSession.DeleteUndoMark(markId4, Nothing)
theSession.SetUndoMarkName(markId2, "Hole")
holePackageBuilder1.HolePosition.CleanMappingData()
Dim expression1 As Expression = holePackageBuilder1.DrillSizeTipAngle
Dim expression2 As Expression = holePackageBuilder1.DrillSizeStartChamferOffset
Dim expression3 As Expression = holePackageBuilder1.DrillSizeStartChamferAngle
Dim expression4 As Expression = holePackageBuilder1.DrillSizeEndChamferOffset
Dim expression5 As Expression = holePackageBuilder1.DrillSizeEndChamferAngle
Dim expression6 As Expression = holePackageBuilder1.DrillSizeHoleDiameter
Dim expression7 As Expression = holePackageBuilder1.ScrewClearanceReliefDepth
Dim expression8 As Expression = holePackageBuilder1.ScrewClearanceNeckChamferOffset
Dim expression9 As Expression = holePackageBuilder1.ScrewClearanceNeckChamferAngle
Dim expression10 As Expression = holePackageBuilder1.ScrewClearanceCountersinkDiameter
Dim expression11 As Expression = holePackageBuilder1.ScrewClearanceCountersinkAngle
Dim expression12 As Expression = holePackageBuilder1.GeneralCounterboreDiameter
Dim expression13 As Expression = holePackageBuilder1.GeneralCounterboreDepth
holePackageBuilder1.Destroy()
theSession.DeleteUndoMark(markId2, Nothing)
Dim holePackage2 As Features.HolePackage = CType(nXObject1, Features.HolePackage)
holePackage2.SetGroupActive(False)
theSession.Preferences.Modeling.UpdatePending = False
Dim projectCurve1 As Features.ProjectCurve = CType(workPart.Features.FindObject("CPROJ(31)"), Features.ProjectCurve)
theSession.UpdateManager.SetUpdateFailureAction(projectCurve1, Update.FailureOption.AcceptAll)
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
TIA for any help
' NX 9.0.2.5
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Try
' Invalid feature.
End Try
End If
End Sub
End Module
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: Hole Edit Journal, NX9
Your code also depends on "Extrude (3)" and "Cproj (31)"; if these features change in the new part, the code may crash.
www.nxjournaling.com
If you can show me how to do it, the name is now = "Thru Hole Top"
The dependency on Extrude(3) & Cproj(31) will always remain in place for this seed file.
Dave
NX9, Win 7 Pro SP1
The code below looks for a hole feature named "test", change the value of holeFeatureName to the name that you choose to use.
CODE
Option Strict Off Imports System Imports NXOpen Module Module1 Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Sub Main() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "C'Bore to C'Sink" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) 'find counterbored screw hole feature with the specified name Const holeFeatureName As String = "test" Dim theHoleFeat As Features.HolePackage Dim found As Boolean = False For Each temp As Features.Feature In workPart.Features If temp.Name = holeFeatureName AndAlso temp.FeatureType = "HOLE PACKAGE" Then found = True theHoleFeat = temp Exit For End If Next If Not found Then lw.WriteLine("hole feature named '" & holeFeatureName & "' not found") Return End If ChangeHoleToCSink(theHoleFeat) Try Dim projectCurve1 As Features.ProjectCurve = CType(workPart.Features.FindObject("CPROJ(31)"), Features.ProjectCurve) theSession.UpdateManager.SetUpdateFailureAction(projectCurve1, Update.FailureOption.AcceptAll) Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.DoUpdate(markId1) theSession.Preferences.Modeling.UpdatePending = False Catch ex As NXException End Try lw.Close() End Sub Sub ChangeHoleToCSink(ByVal theHole As Features.HolePackage) Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "change to csink") Try ' Invalid feature. theHole.SetGroupActive(True) Catch ex As NXException ex.AssertErrorCode(670060) End Try If Not workPart.Preferences.Modeling.GetHistoryMode Then Throw (New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode.")) End If Dim holePackageBuilder1 As Features.HolePackageBuilder holePackageBuilder1 = workPart.Features.CreateHolePackageBuilder(theHole) With holePackageBuilder1 .HolePosition.PrepareMappingData() .ScrewClearanceHoleForm = Features.HolePackageBuilder.HoleForms.Countersink .ScrewClearanceCountersinkDiameter.RightHandSide = "0.507" .ScrewClearanceReliefDepth.RightHandSide = "0.06" .ScrewType = "Machine (82 degree)" .StartHoleData.ScrewType = "Socket Head, 4762" .StartHoleData.ScrewSize = "M1.6" .StartHoleData.FitOption = "Close (H12)" .MiddleHoleData.FitOption = "Close (H12)" .EndHoleData.FitOption = "Close (H12)" End With Dim nXObject1 As NXObject nXObject1 = holePackageBuilder1.Commit() holePackageBuilder1.HolePosition.CleanMappingData() holePackageBuilder1.Destroy() Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.DoUpdate(markId1) End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
Dave
NX9, Win 7 Pro SP1
