Radial and axial force for screw pump
Hi all,[/s]
I having tough time identifyiny the radial force and axial force of twin screw pump. Can anyone tell me what area subjected to determine the radial and axial force.appreciate your reply.
RE: Radial and axial force for screw pump
Hi Tmoose,
I have referred that particular documents and many other documents available on web. Anywhere they are not saying about the manually determining. the radial and axial loads. Infact they says ,it is tricky to determine the exact area which comes in effect for calculating the forces.and suggesting rotodynamic analysis. But I cannot do that . So I would need help in identifying atleast approximate way in determining the area to be considered. Appreciate your reply.
