Bolt size
Bolt size
Hello Members,
This may be a stupid question.
Under sized bolts are used in some of the piping systems as follows,
16" - 300# flange
Used bolt size: 1 1/8"
As per ASME: 1 1/4"
The design pressure of the piping system is 25bar.
We found this discrepancy at the later stage of the project and changing now is huge task since the scaffolds and other resources are already demobilized.
Could any of the member ever came like this situation and what was the final decision made?
Is there any deviation/tolerance in ASME codes?
Thanks for your valuable feedback.
16" - 300# flange
As per ASME: 1 1/4"
RE: Bolt size
although interrelated components: the flanges,
gasket, and bolting, which are assembled by another
influence, the assembler. Proper controls must be exercised
in the selection and application for all these elements
to attain a joint that has acceptable leak tightness.
Your only get out is section 2.3.1 which basically says use of the flange ratings which do not comply with the standards is "the responsibility of the user". How good is your liability insurance??
Nearly always the only way to resolve to everyones satisfaction is to break out the cherry picker or get the scaffolders back ASAP.
Apart from the issue of bolt stress, you also have the issue of nut contact area being less. If you've used washers, they can become over stressed.
RE: Bolt size
It is a lot easier to correct a situation like this if it is noticed as soon as sub-systems are installed and scaffolding/platforms are still in place.
The only questions that come to mind are:
1) Was the smaller bolting/stud substitution done because of fastener availability ?
2) If the bolting/stud fasteners are the wrong size, have you checked the materials ? Was A193/A194 materials specified but something else supplied
3) Has this contractor supplied other piping systems, for you or others in the past and were the flanges checked ?
4) Have these systems been pressure tested yet ? What were the results ?
25 bar is significant pressure.....
MJCronin
Sr. Process Engineer
RE: Bolt size
Thank you MJCronin!
for your feedback.
The lines were hydro tested tested with 1.5 times the design pressure. Fortunately there was no safety incident during the high pressure test due to the inadequate bolt size.
RE: Bolt size
RE: Bolt size
RE: Bolt size
My Sig line seems applicable here :)
Mike
RE: Bolt size
Maybe I missed something, but I don't see the problem here.
RE: Bolt size
Mike
RE: Bolt size
Looking at the comments above, it seems clear that it is not possible to state that this is according to the given standard for the project. Although it anyway could be well within mechanical acceptable forces (at the present given application), it is no more within standard for this reason.
Things 'just a tiny bit out of standard' can go wrong, for instance by longterm pipe-stress or altered pressure conditions.
As said above: The cost of consequences if failure can be far higher than the cost of correcting now, and claims of changing can come later, even if 'someone' says OK now.
RE: Bolt size
www.engineeringtoolbox.com/flanges-bolts-dimension...
RE: Bolt size
RE: Bolt size
NOM OD ID BH No. Bolt size Bolt lenghts
16 650 571.5 1 3⁄8" 20 1 1⁄4" 190 205 165
RE: Bolt size
We have decided to replace the bolts as per ASME B16.5.
RE: Bolt size
Mike
RE: Bolt size
