Customer Default settings
How can I apply my current user settings to an existing part?
When I went to customer default and change it, it does not apply it to existing part.
I have to go to preferences and do the changes there. As an example, I want my solids, sheets, and curves a certain color. Every time I work on an existing part, I have to change the object preferences.
TIA!
TIA!
UGNX 8 / 8.5 / 9 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
RE: Customer Default settings
If there are many existing parts that you need to change, you can record a macro or journal to quickly apply your changes to the files.
www.nxjournaling.com
I have no problem with new parts.
What I would like to do is when I open an existing part, I would be able to replace the default setting with a minimum of commands. Settings would be object preference, modelling preference, etc. I am hoping it would be similar to changing the icons setup. I have saved my icon setup and I just go to customize and load my *.mtx file.
