STAAD command for member release
Does anyone have a shortcut method for this. At present, to assign a member release, you have to go to commands/member specifications/release.
If you have a complex model, this can take a lot of time.
Is it possible to set a function key to operate this commend in a single stroke ?
RE: STAAD command for member release
I Look forward to this
Really, selecting beams in a complex structure is the time consuming part. There are a lot of tricks you can use when selecting beams to speed things up. Pull down the select menu and look over the choices. You can also isolate parts of the structure by using the "New view" command. Right click with members to selected to see this. With some practice you will get better selecting members quickly.
