Half Cutted 48" Pipe Receiving Load
hi, everyone, as a junior engineer i hope some seniors can help me.
i have a case:
i need a protection for live pipe,
the lastest idea was to cover the live pipe with half cutted 48" and restrained with some channel structure below it.
the skecth for this
this casing will be covered with 1 m thickness soil.
and a some heavy equipmen will go above it.
lets say the load will be 30 Tonne.
my question is.
how i calculated the pipe will not break/bending or simply i want to calculate the strength of half pipe.
i tried to use sap2000 to make a model of it, but all i get is displacement and stress working in the pipe.
or there is a way to check "ratio" of steel plate?
if its a concrete plate i understand what to do with the the stress/moment working in the plate,
but for steel? can someone giving explanation or even reference i can read to understand this. i need this.
Spawl
i have a case:
the skecth for this
my question is.
Spawl
RE: Half Cutted 48" Pipe Receiving Load
1) Check your stresses against allowable stresses per AISC manual recommendations.
2) Check plate buckling which is going to be tough. You may need to dig a bit deeper for that: Link
BUGGAR : cant do that, if i buy manufactured culvert ill takes 1 month to arrive to the site. expediting things is a very hard case here. lol
You could make your first lift of backfill out of lean concrete. After it sets up, backfill the rest of the way per usual. Soil cement would work.
