Soil pressure diagram behind gravity retaining wall
Hello, I have a question for geotechnical engineers. Consider typical reinforced concrete gravity retaining wall, constructed by usual method: 1)excavate behind the heel, 2)construct the wall, 3) Backfill behind the wall.
In case of taller wall (say 15 feet +) and two distinct native soil layers above the footing, would you specify two lateral earth pressure coefficients (and unitweight) or just one. Would it be native soil or backfill parameters.
This is a conceptual question, not based on particular life example.
Thank you for responses!
Yakpol
Yakpol
RE: Soil pressure diagram behind gravity retaining wall
Yakpol
Mike Lambert
