Extraction of Stresses with Python at each integration points
online
1 post
This post has NOT been accepted by the mailing list yet.
I m trying to extract the stresses with Python at each integration points (or an extrapolation to the nodes). I get the stresses but i dont succeed to use a nodelabel or something like that to
know where i m extracting data...
My aim is to extract some values as plastic strain and re use it in an other calculation so i
need to know exactly the labelling
My code is :
from odbAccess import *
import numpy as np
odb = openOdb(path='C:/Users/Jerome/Desktop/test_couplageFEM_DIC/Fish.odb')
lastFrame = odb.steps['Step-1'].frames[-1]
stress=lastFrame.fieldOutputs['S']
sortie = open('Resu_PE_maillage.txt', 'w')
sortie.write('Node label \t S11 \t\t S22 \t\t S33 \t\t S12 \t\t S23 \t\t S13 \n')
for S in stress.values:
sortie.write('%.10e\t\t %.10e\t\t %.10e\t\t %.10e\t\t %.10e\t\t %.10e\n' % (S.data[0], S.data[1], S.data[2], S.data[3], S.data[4], S.data[5]))
sortie.close()
1 post
My code is :
import numpy as np
sortie.close()
RE: Extraction of Stresses with Python at each integration points
Check the "Report" option in /CAE postprocessing. Here you can export these results to an ASCII file.
The location of the integration points can be requested as output with
*Element Output, Position=Integration Points
COORD
But i would like to optimize this obtainement because i would re use some results as plastic strains in further
computations
You could easily extract the extrapolated (but unaveraged) values at nodes. Just request them for the analysis to get them written in the ODB.
*Element Output, Position=Nodes
S
I have 6.13 Abaqus and i m looking for in the "Edit Field Output Request"
or i have to add that in my inp file?
Thanks for your help
Averaging is done during graphical postprocessing. A report could write these values in a file.
So at the end of my .inp file, i have to add "*Element Output, Position=Nodes" in field output?
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
*Output, field
S
You can modify that depending on the variables you would like to have or the output frequency.
See Abaqus Users Manual 4.1.3 Output to the output database
