Sel fixed roof or fixed roof ?
Hello
Could you advise me about when can I design a storage tank with self fixed roof or fixed roof?
For example for a tank API 650 of 10 meters of diameter and 13 meters of height, which type of roof is better?
RE: Sel fixed roof or fixed roof ?
I am trying with vegetable oil and Diesel, with the dimensions that I said above.
What kind of conical roof do you recommend me ?
If so, the difference is partly owner preference (for corrosion concerns, etc.), partly design (steeper roofs work better with pressure) and mainly economic (whichever can be built cheaper in a given case). That last item would vary from situation to situation, and would depend on your erection equipment, labor costs, and other details.
