Need to modify mix to make it more flowable
I have this mix,
1 Cubic yard
Portland Cement Type 1 846 pounds
Concrete Sand 1100 pounds
#57 Crushed Limestone 1700 pounds
Water 267 pounds
Air 3%
HRWR (as needed)42 ounces
Retarder (as needed)21 ounces
W/C Ratio 0.32
PVA macrofibers 96 ounces
PVA microfibers 48 ounces
This is for casting concrete spheres. The fewer voids and bugholes I have will lead to less labor and more predictable finished weights. I got a viscosity modifying admixture, Visctrol from Euclid Chemical, and did two batches. At a dosing of 2 oz per 100 pounds of cement I didn't notice any change. The second time I probably used a dosing of 6 oz per 100 pounds of cement and didn't notice any change in the flowablity. The only difference I noticed was no bleed water at the top of the mold, which is a big advantage for me.
How can I modify this to still maintain a high level of strength, but have a very flowable mixture? I don't know if I want true SCC, but something close would be nice.
1 Cubic yard
Water 267 pounds
Air 3%
W/C Ratio 0.32
RE: Need to modify mix to make it more flowable
But I'm not sure anything is going to eliminate bugholes.
Do you have any options for different sand gradations? Type III cement could be a helpful tool.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
Professional and Structural Engineer (ME, NH)
American Concrete Industries
www.americanconcrete.com
Mike McCann, PE, SE (WA)
For use in the field and the usual batching equipment super plasticizers are they way to go.
Dick
The paper describing the mix had it listed at a touch over 10,000 psi, if 50% slag cement is used. I want something as strong as possible. I make atlas stones which are used in strongman contests and dropped repeatedly, I don't want them cracking. I have searched for supplemental cementing materials and all I can find in small quantities is silia fume. This is just a small business I run out of my garage.
"Since this is apparently casting in a plant, has vibration (unidirectional, directional or random) been considered for the spheres you make? That may affect the air content.
Do you have any options for different sand gradations?"
I do this out of my garage and all I have is a palm sander to vibrate the outside of the mold. A dedicated concrete vibrator is unaffordable at this time. Regarding sand gradations, I haven't looked much into this. Off the top of my head I know I have easy access to concrete sand and sand meant for children's sandboxes.
"What about super-plasticizers? "
I use a one at just over the maximum suggested ration,12 oz per 100 pounds of cement.
Thanks for the suggestions, I will mix up a few small doses with less cement and varying W/C ratios and see how they work. I appreciate the feedback.
This will go a long way toward removing tapped air from your concrete and result in a much better product.
