Kerosene to jet fuel refining
Dear engineers,
I am tasked with designing a plant converting carbon dioxide and oxygen to jet fuel. A fischer tropsch reator is being used to generate syncrude, I am just wondering if it would be possible to use a conventional merox process to refine the kerosene distilled from syncrude could be used in a merox process like kerosene from crude oil distillation, struggling to find information on this in books. Many thanks in advance.
RE: Kerosene to jet fuel refining
MJCronin
Sr. Process Engineer
Anyway, kero is a large component of jet fuel for some jet fuel grades. Do you actually mean hydrotreating to reduce smoke point/lower the freeze point, which will also reduce sulphur content ?
Maybe its just me, but to manufacture a hydrocarbon, surely you need hydrogen molecules. CO2 and O2 don't contain any....
Jet fuel is kerosene, just a particular clean and dry version.
Given the issues about pour fuel in airplanes, I would think that there are many other markets for syn crude than jet fuel.
That is once you've located the hydrogen atoms...
Doing this is utterly dumb-ass from a thermochemical/energetic point of view. You would be far better off starting with ANY other carbon source than CO2 and generating syngas by pyrolysis or gasification of that carbonaceous material. CO2 is at the very bottom of the Gibbs energy well because it is fully oxidized, which is why it is the most desirable combustion PRODUCT- and by definition, the worst fuel feedstock imaginable.
Want to make formic acid, formaldehyde etc? Starting with CO2 might have some merit. But as a starting point for fuel? Forget it.
I am afraid that using all of your fancy "book-learnin" and laws of thermodynamics is only going to discourage young Jamill.....
His MBA manager is not going to want to hear this. He tasked Jamill with the job of turning carbon dioxide and oxygen into jet fuel.
I suggest that we all give him encouragement and quote some of those wonderful teamwork catch phrases....
https://s-media-cache-ak0.pinimg.com/736x/9f/89/d1...
If you are really committed to a task......you can accomplish anything !!!
Hydrogen be damned !!!!
MJCronin
Why would the seeming complete academe of hydrogen atoms make a difference....???
