Can you please help with this problem in Abaqus ?
Hello !
I am currently doing a simulation of a 2D hollow cylinder (plane-strain assumption) falling on to the ground with a initial velocity of 5m/s from a height of 2m and allowing it to keep bouncing until it comes to rest. I carried out this simulation and obtained the graph (shown in attachment 1) and again i restarted with a new step to obtain the next graph (shown in attachment 2).
Problem:
I want to join the two graphs (meaning the end point of the first graph should be the start point of the second graph). I tried by first creating the XY datas as shown in the pictures above. Then i tried TOOLS -->XY Data--->CREATE----> OPERATE ON XY DATA ----> OPERATOR : append ((X,X....)) and I managed to get a graph (shown in attachment 3) with an expression---> append (("XYData-1", "XY Data-2")) as shown below:
But as stated before I want the end point of graph 1 to be the start point of graph 2. I am not able to figure out a right expression for it. So please help me to fix this problem. Any help in this regard is appreciable.
Thank you.
Problem:
Thank you.
RE: Can you please help with this problem in Abaqus ?
Open the XY data manager and use Edit to look at the data. You'll see, that both data have a time from 0 to 1. Your second graph needs a step time from 1 to 2.
So open that graph with Edit, copy the data to Excel, add a 1 to the whole time row and bring it back to CAE. Then it should work.
