Stainless steel burr.
Hi, Im new to this forum and still somewhat new to laser cutting. my question would be, how do I get 2.5mm thick 304 stainless steel to cut with NO burr or slag on it or minimal burr or slag. the company Im working at has a Prima Optimo 5 axis laser cutter. Im trying to cut 2.5mm thick 304 stainless steel and there is a burr on it about 0.010in or 0.254mm thick. Here are the cutting parameters Im currently using, Shutter:3, Type:2, Power:700, Frequency:80, DutyC:20, Gas Pressure:4.0, Gas Type:Oxygen. Im also using a 1.5mm tip. My standoff is 1.2mm. I have tried probably a hundred different changes to my parameter settings and so far this is the best I have found. I do also have the option to use Nitrogen at my shop. If you have any knowledge that would help me out then Id greatly appreciate it. Thanks!
RE: Stainless steel burr.
