Dimension origin symbol
How can I have an origin symbol (circle) on one end of a dimension leader and an arrow on the other end? I thought I could do this in earlier versions of SW (I'm running 2015). The only way I found to do it now is change the overall drafting standard from ANSI to JIS, change the dim arrow option, then change back fro JIS to ANSI. If you have an alternative method I'd appreciate knowing what it is.
tia, Diego
tia, Diego
RE: Dimension origin symbol
