Assembly Navigator difference in part visibilities?
I have added two different components to a model in NX.
These appear in the Assembly Navigator, but only one of them is usable/visible (this one has a checked box in front of the file-name).
The other part has a dotted box in front of the file name together with a pink-lined-box icon.
Which settings are different in these files? I am searching for a while, but I cannot find anything. It is probably a very simple issue.
The attachment shows the difference.
kopjeroen
kopjeroen
RE: Assembly Navigator difference in part visibilities?
www.nxjournaling.com
Can I also change a setting in the part itself, so I won't have to change this setting after the component is loaded?
In the Attributes (File > Properties) the DB_UNITS had a value. I have deleted this value and the problem is solved.
I found out that something was changed in the Attributes setting of the part (template file).
DB_UNITS had a value, thats why NX saw the component as being non-geometric.
When I deleted this value and added the component to the assembly, NX saw it as a regular component and not as being non-geometric.
