cyclopean or soil replacement
In one of the projects, the geotechnical is advising to rest the bottom of the isolated foundations on 1.5m cyclopean concrete.
This will cost a lot of Money.
I was thinking of replacing the soil by a good backfill soil instead of all this concrete operation.
the buildng is 4 stories height with some large spans (up to 9 meters).
I am looking for some explanations when to go for cyclopean concrete instead of soil replacement.
Many thanks
Many thanks
RE: cyclopean or soil replacement
Ron, I dont have any boring log about the soil.
WARose, this isnt the case. A good soil for replacement can be provided and it is that far.
So if i understand well soil replacement can be replaced by this cyclopean thing, right ?
Will the excavation for your footings be the same size as the footing or larger? If larger, I can see that the concrete would help in distributing the load. If the same size, compacted granular material should work, unless there is a concern that the granular filled void would be a reservoir, leading to some sort of degredation of the underlying soils.
Would a lean concrete mix be of any use here? And, a replacement for a somewhat more complicated placement process and a more complicated materials handling process?
I too had to look up the term.
