Journal to edit multiple attributes using Windows Forms
Here is a journal to edit a few attributes using a windows form. I created this because the new attribute editor is cumbersome.
CODE --> basic
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
Private _formTitle As String = ""
Public ReadOnly Property FormTitle() As String
Get
Return _formTitle
End Get
End Property
Private _attributeTitle As String = ""
Public ReadOnly Property AttributeTitle() As String
Get
Return _attributeTitle
End Get
End Property
Private _attributeName As String = ""
Public Property AttributeName() As String
Get
Return _attributeName
End Get
Set(ByVal value As String)
_attributeName = value
End Set
End Property
Private _attributePartNo As String = ""
Public Property AttributePartNo() As String
Get
Return _attributePartNo
End Get
_attributePartNo = value
End Set
End Property
Private _attributeShape As String = ""
Public Property AttributeShape() As String
Get
Return _attributeShape
End Get
_attributeShape = value
End Set
End Property
Private _attributeWeight As String = ""
Public Property AttributeWeight() As String
Get
Return _attributeWeight
End Get
_attributeWeight = value
End Set
End Property
Private _attributeProc As String = ""
Public Property AttributeProc() As String
Get
Return _attributeProc
End Get
_attributeProc = value
End Set
End Property
Sub Main()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim theSession As Session = Session.GetSession()
If IsNothing(theSession.Parts.Work) Then
'active part required
Return
End If
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Dim lg As LogFile = theSession.LogFile
Const undoMarkName As String = "NXJ form journal"
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
Dim myAttributeInfo As NXObject.AttributeInformation
_attributeTitle = "PARTNUMBER"
Try
myAttributeInfo = workPart.GetUserAttribute(_attributeTitle, NXObject.AttributeType.String, -1)
_attributePartNo = myAttributeInfo.StringValue
Catch ex As NXException
If ex.ErrorCode = 512008 Then
'attribute not found
Else
'unexpected error: show error message, undo, and exit journal
MsgBox(ex.ErrorCode & ": " & ex.Message)
theSession.UndoToMark(markId1, undoMarkName)
Return
End If
Finally
End Try
_attributeTitle = "NAME"
Try
_attributeName = myAttributeInfo.StringValue
Else
Return
End If
Finally
End Try
_attributeTitle = "WEIGHT"
Try
myAttributeInfo = workPart.GetUserAttribute(_attributeTitle, NXObject.AttributeType.Real, -1)
_attributeWeight = myAttributeInfo.StringValue
Else
Return
End If
Finally
End Try
_attributeTitle = "SHAPE"
Try
_attributeShape = myAttributeInfo.StringValue
Else
Return
End If
Finally
End Try
_attributeTitle = "PROCUREMENTCODE"
Try
_attributeProc = myAttributeInfo.StringValue
Else
Return
End If
Finally
End Try
_formTitle = _attributePartNo & " - " & _attributeName & " - Attributes"
Dim myForm As New Form1
'set form object properties (current part attribute title and value)
myForm.AttributePartNo = _attributePartNo
myForm.AttributeName = _attributeName
myForm.AttributeWeight = _attributeWeight
myForm.AttributeShape = _attributeShape
myForm.AttributeProc = _attributeProc
myForm.FormTitle = _formTitle
'display our form
ufs.Abort.DisableAbort()
myForm.ShowDialog()
If myForm.Canceled Then
ufs.Abort.EnableAbort()
'user pressed cancel, exit journal
Return
Else
'user pressed OK, assign value from form to part attribute
Try
workPart.SetUserAttribute("PARTNUMBER", -1, myForm.AttributePartNo, Update.Option.Later)
Catch ex As Exception
lg.WriteLine(ex.ToString)
End Try
Try
workPart.SetUserAttribute("NAME", -1, myForm.AttributeName, Update.Option.Later)
End Try
Try
workPart.SetUserAttribute("SHAPE", -1, myForm.AttributeShape, Update.Option.Later)
End Try
Try
workPart.SetUserAttribute("PROCUREMENTCODE", -1, myForm.AttributeProc, Update.Option.Later)
End Try
Try
workPart.SetUserAttribute("WEIGHT", -1, CType(myForm.AttributeWeight, Double), Update.Option.Later)
End Try
End If
End Sub
End Module
Public Class Form1
Private _frmTitle As String
Public Property FormTitle() As String
Get
Return _frmTitle
End Get
_frmTitle = value
End Set
End Property
Private _frmAttributeTitle As String
Public Property AttributeTitle() As String
Get
Return _frmAttributeTitle
End Get
_frmAttributeTitle = value
End Set
End Property
Private _frmAttributeName As String
Get
Return _frmAttributeName
End Get
_frmAttributeName = value
End Set
End Property
Private _frmAttributePartNo As String
Get
Return _frmAttributePartNo
End Get
_frmAttributePartNo = value
End Set
End Property
Private _frmAttributeProc As String
Get
Return _frmAttributeProc
End Get
_frmAttributeProc = value
End Set
End Property
Private _frmAttributeShape As String
Get
Return _frmAttributeShape
End Get
_frmAttributeShape = value
End Set
End Property
Private _frmAttributeWeight As String
Get
Return _frmAttributeWeight
End Get
_frmAttributeWeight = value
End Set
End Property
Private _canceled As Boolean = False
Public ReadOnly Property Canceled() As Boolean
Get
Return _canceled
End Get
End Property
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Me.Text = _frmTitle
TextBox_Name.Text = _frmAttributeName
TextBox_PartNo.Text = _frmAttributePartNo
TextBox_Proc.Text = _frmAttributeProc
TextBox_Shape.Text = _frmAttributeShape
TextBox_Weight.Text = _frmAttributeWeight
End Sub
Private Sub btnCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnCancel.Click
_canceled = True
Me.Close()
End Sub
Private Sub btnOK_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOK.Click
_frmAttributeName = TextBox_Name.Text.ToUpper
_frmAttributePartNo = TextBox_PartNo.Text.ToUpper
_frmAttributeProc = TextBox_Proc.Text.ToUpper
_frmAttributeShape = TextBox_Shape.Text.ToUpper
_frmAttributeWeight = TextBox_Weight.Text.ToUpper
Me.Close()
End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Form1
Inherits System.Windows.Forms.Form
'Form overrides dispose to clean up the component list.
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Me.Label1 = New System.Windows.Forms.Label()
Me.btnOK = New System.Windows.Forms.Button()
Me.TextBox_Name = New System.Windows.Forms.TextBox()
Me.Label2 = New System.Windows.Forms.Label()
Me.Label3 = New System.Windows.Forms.Label()
Me.Label4 = New System.Windows.Forms.Label()
Me.Label5 = New System.Windows.Forms.Label()
Me.TextBox_PartNo = New System.Windows.Forms.TextBox()
Me.TextBox_Shape = New System.Windows.Forms.TextBox()
Me.TextBox_Weight = New System.Windows.Forms.TextBox()
Me.TextBox_Proc = New System.Windows.Forms.TextBox()
Me.SHAPE_CALC = New System.Windows.Forms.Button()
Me.WEIGHT_CALC = New System.Windows.Forms.Button()
Me.btnCancel = New System.Windows.Forms.Button()
Me.SuspendLayout()
'Label1
Me.Label1.AutoSize = True
Me.Label1.Location = New System.Drawing.Point(11, 12)
Me.Label1.Name = "Label1"
Me.Label1.Size = New System.Drawing.Size(38, 13)
Me.Label1.TabIndex = 0
Me.Label1.Text = "NAME"
Me.Label1.UseMnemonic = False
'btnOK
Me.btnOK.Location = New System.Drawing.Point(82, 174)
Me.btnOK.Name = "btnOK"
Me.btnOK.Size = New System.Drawing.Size(75, 23)
Me.btnOK.TabIndex = 6
Me.btnOK.Text = "OK"
Me.btnOK.UseVisualStyleBackColor = True
'TextBox_Name
Me.TextBox_Name.Location = New System.Drawing.Point(82, 12)
Me.TextBox_Name.Name = "TextBox_Name"
Me.TextBox_Name.Size = New System.Drawing.Size(149, 20)
Me.TextBox_Name.TabIndex = 1
'Label2
Me.Label2.AutoSize = True
Me.Label2.Location = New System.Drawing.Point(12, 38)
Me.Label2.Name = "Label2"
Me.Label2.Size = New System.Drawing.Size(58, 13)
Me.Label2.TabIndex = 0
Me.Label2.Text = "PART NO."
'Label3
Me.Label3.AutoSize = True
Me.Label3.Location = New System.Drawing.Point(12, 64)
Me.Label3.Name = "Label3"
Me.Label3.Size = New System.Drawing.Size(43, 13)
Me.Label3.TabIndex = 0
Me.Label3.Text = "SHAPE"
'Label4
Me.Label4.AutoSize = True
Me.Label4.Location = New System.Drawing.Point(12, 89)
Me.Label4.Name = "Label4"
Me.Label4.Size = New System.Drawing.Size(51, 13)
Me.Label4.TabIndex = 0
Me.Label4.Text = "WEIGHT"
'Label5
Me.Label5.AutoSize = True
Me.Label5.Location = New System.Drawing.Point(12, 115)
Me.Label5.Name = "Label5"
Me.Label5.Size = New System.Drawing.Size(37, 13)
Me.Label5.TabIndex = 0
Me.Label5.Text = "PROC"
'TextBox_PartNo
Me.TextBox_PartNo.Location = New System.Drawing.Point(82, 38)
Me.TextBox_PartNo.Name = "TextBox_PartNo"
Me.TextBox_PartNo.Size = New System.Drawing.Size(149, 20)
Me.TextBox_PartNo.TabIndex = 2
'TextBox_Shape
Me.TextBox_Shape.Location = New System.Drawing.Point(82, 64)
Me.TextBox_Shape.Name = "TextBox_Shape"
Me.TextBox_Shape.Size = New System.Drawing.Size(149, 20)
Me.TextBox_Shape.TabIndex = 3
'TextBox_Weight
Me.TextBox_Weight.Location = New System.Drawing.Point(82, 89)
Me.TextBox_Weight.Name = "TextBox_Weight"
Me.TextBox_Weight.Size = New System.Drawing.Size(149, 20)
Me.TextBox_Weight.TabIndex = 4
'TextBox_Proc
Me.TextBox_Proc.Location = New System.Drawing.Point(82, 115)
Me.TextBox_Proc.Name = "TextBox_Proc"
Me.TextBox_Proc.Size = New System.Drawing.Size(149, 20)
Me.TextBox_Proc.TabIndex = 5
'SHAPE_CALC
Me.SHAPE_CALC.Location = New System.Drawing.Point(247, 64)
Me.SHAPE_CALC.Name = "SHAPE_CALC"
Me.SHAPE_CALC.Size = New System.Drawing.Size(75, 23)
Me.SHAPE_CALC.TabIndex = 0
Me.SHAPE_CALC.Text = "Calculate"
Me.SHAPE_CALC.UseVisualStyleBackColor = True
Me.SHAPE_CALC.Visible = False
'WEIGHT_CALC
Me.WEIGHT_CALC.Location = New System.Drawing.Point(247, 89)
Me.WEIGHT_CALC.Name = "WEIGHT_CALC"
Me.WEIGHT_CALC.Size = New System.Drawing.Size(75, 23)
Me.WEIGHT_CALC.TabIndex = 0
Me.WEIGHT_CALC.Text = "Calculate"
Me.WEIGHT_CALC.UseVisualStyleBackColor = True
Me.WEIGHT_CALC.Visible = False
'btnCancel
Me.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.btnCancel.Location = New System.Drawing.Point(177, 174)
Me.btnCancel.Name = "btnCancel"
Me.btnCancel.Size = New System.Drawing.Size(75, 23)
Me.btnCancel.TabIndex = 7
Me.btnCancel.Text = "Cancel"
Me.btnCancel.UseVisualStyleBackColor = True
'Form1
Me.AcceptButton = Me.btnOK
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.btnCancel
Me.ClientSize = New System.Drawing.Size(337, 205)
Me.Controls.Add(Me.btnCancel)
Me.Controls.Add(Me.WEIGHT_CALC)
Me.Controls.Add(Me.SHAPE_CALC)
Me.Controls.Add(Me.TextBox_Proc)
Me.Controls.Add(Me.TextBox_Weight)
Me.Controls.Add(Me.TextBox_Shape)
Me.Controls.Add(Me.TextBox_PartNo)
Me.Controls.Add(Me.Label5)
Me.Controls.Add(Me.Label4)
Me.Controls.Add(Me.Label3)
Me.Controls.Add(Me.Label2)
Me.Controls.Add(Me.TextBox_Name)
Me.Controls.Add(Me.btnOK)
Me.Controls.Add(Me.Label1)
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "Form1"
Me.SizeGripStyle = System.Windows.Forms.SizeGripStyle.Hide
Me.Text = "Menu"
Me.ResumeLayout(False)
Me.PerformLayout()
End Sub
Friend WithEvents Label1 As System.Windows.Forms.Label
Friend WithEvents btnOK As System.Windows.Forms.Button
Friend WithEvents TextBox_Name As System.Windows.Forms.TextBox
Friend WithEvents Label2 As System.Windows.Forms.Label
Friend WithEvents Label3 As System.Windows.Forms.Label
Friend WithEvents Label4 As System.Windows.Forms.Label
Friend WithEvents Label5 As System.Windows.Forms.Label
Friend WithEvents TextBox_PartNo As System.Windows.Forms.TextBox
Friend WithEvents TextBox_Shape As System.Windows.Forms.TextBox
Friend WithEvents TextBox_Weight As System.Windows.Forms.TextBox
Friend WithEvents TextBox_Proc As System.Windows.Forms.TextBox
Friend WithEvents SHAPE_CALC As System.Windows.Forms.Button
Friend WithEvents WEIGHT_CALC As System.Windows.Forms.Button
Friend WithEvents btnCancel As System.Windows.Forms.Button
End Class Design Engineer, NX 8.5
