How to extract manually defined shear wall sections into tables
Hello all,
Its great to be part of this forum since this is my first post.
Here is my query:
I am designing a building and for the pier/shear walls I followed the General Reinforcing Pier Section approach.
I defined all the pier sections (at "Define Pier Sections for checking...") and manually input the required reinforcement bars with "Section Designer...". Then I assigned accordingly in order to check if the reinforcement ratio is below 1. My question is how can I extract the sections that I defined into tables ("Show Tables..." or "Print Tables...")? Is there an option for doing this?
Thank you in advance for your time.
C
