Customizing radial popup buttons in NX9
I would like to know if there's a way to customize the radial popup buttons when you hold down Ctrl+Shift and hold down MB1, MB2 or MB3. I would like to customize all three radials if possible. For example, on the Ctrl+Shift+MB1 radial I never use Datum CSYS, Draft, Hole or Revolve. I would like to replace them with Remove Parameters, Move Component, WCS Origin and Measure Distance. I would also like to fill up the empty spots on the Ctrl+Shift+MB1 menu. Thanks for your time!
Rick
RE: Customizing radial popup buttons in NX9
That's it! Thank you so much!
