Filtering shower water
I am currently working on a small project for dry cabins in Alaska without running water. The cabin is heated using a wood stove, so I am using that to heat the shower water. I want to use a closed loop shower system where I can filter the shower water after use and keep reusing it for a week or month period. Is there an economical way to filter the soap from the shower water??
This is my first post, so please redirect me if I am in the wrong sub.
Thank you
Thank you
RE: Filtering shower water
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Keith Cress
You would have to use a prefilter, then Reverse Osmosis, then UV to disinfect the water. Probably would cost over $10,000 for the equipment and you probably will not be able to afford the operating costs. There will significant power requirement to operate it which is a problem out in the woods. The RO will also waste 20-30% of the wastewater as well.
You can recycle the shower water as grey water for use in the toilets. That is an easier proposition.
The wastewater market has annual sales of around $200 billion US. If water recycling was such a simple problem, recycling of shower water would already have been solved.
My understanding is that the orbital system has never made it into production. The orbital "inventor" as he has been described is an industrial designer. The water recycling problem is not something that can be solved by a designer with no experience in water treatment. The orbital video does shows the filter cartridges but does not show a pump. The installation also shows a 400V 15 amp power supply is necessary. Most houses do not have 400V power available.
Orbital compares a water shower to the space station. The space station crew does not use a water shower. See the attached article on the complex water recycling system that is installed on the space station. The design of the water recycling system in the space station is also still under development. The comparison to the space station is misleading.
At this point, the orbital concept is just smoke and mirrors.
One reviewer calls it "crazy".
http://www.extremetech.com/extreme/170784-recyclin...
