Harmonic/Spectrum Analysis?
Hello everyone!
I need to model a telecommunication tower that is vibrating/moving under wind load. I have a video of the top of the tower moving from where I can get an ideia of the period of that movement. How can I determine the structural forces of the members?
I've performed a static analysis using critical project wind loads, followed with a modal analysis(pstress,on). LINK8 and BEAM188 elements showed similar results, so i kept the LINK8 model. Mode periods are close from what can I see on that video. The question is... how can i proper extract the forces?
An harmonic analysis requires an harmonic force, that I don't have. I can use it to determine frequencies that will have a DOF peak but I already know that these are the modes natural frequencies.
An Spectrum analysis requires a (Freq) x (Force amplification coefficient) curve that I also don't have and don't fully understand. I get freq x acel curves for seismic analysis but can't see how it works for wind forces.
I've tried both, for the same load configuration with a frequency range of 0.1-100Hz and force amplification always 1(for the spectrum model). Both models results were lower than the pure static analysis....
I think that perfect model would extract the modes and then impose a vibration pattern on the structure, from where I would get the forces.
Can anyone help? I could not find any documentation regarding this kind of problem...
Best Regards,
Luciano S. Engel
