OIL MANAGER ON HYSYS
Dear friends ;
I have an ASTM D86 distillation data for a JET A-1 STREAM from the laboratory
the data contains :
initial boiling point (°C)
10% DISTILLATION TEMPERATURE (°C)
20% DISTILLATION TEMPERATURE (°C)
50% DISTILLATION TEMPERATURE (°C)
90 % DISTILLATION TEMPERATURE (°C)
End point (°C)
Residue ( %V)
Loss ( %V)
My questions are below :
1) Does initial boiling point means at 0% cut point ?
2) Does initial boiling point means at 100% cut point ?
3) Does the Residue ( %V) and Loss ( %V) should be inputted in the oil manager , if yes where to input them exactly?
Im wondering if anyone could guide me please ?
Thanks a lot !
Regards !
the data contains :
End point (°C)
Residue ( %V)
Loss ( %V)
Thanks a lot !
Regards !
RE: OIL MANAGER ON HYSYS
As for the IBP/FBP, you can use the values such as 1% for IBP and 98% for FBP. There is no significant difference if one would use 0.1% and 100% for IBP and FBP, respectively. You can do both and see the differences yourself.
Dejan IVANOVIC
Process Engineer, MSChE
Thanks a lot EmmanuelTop
I would like to add that the laboratory data contains also :
total sulfur (%mass )
Mercaptan sulfur (%mass )
then : Should I add them as pure components ?
TOTAL SULFUR is S-Amorphous OR S-RHOMBIC on hysys ?
and for Mercaptan sulfur :there are M-MARCAPTON AND E-MARCAPTON ( how to split the mass fraction between the two compond ?)
REGARDS !
Dejan IVANOVIC
