Texture of ADA Ramps
Has anyone come up with a suitable way to texture the ramp surface on ADA depressed curbs? The buttons are too difficult to form. We are contemplating grooving. Worried about catching water/ice in winter, or womens high heels any other time. Has anyone tried grooving with a slight downhill slope? What width groove and landing between grooves? Any non-grooved sections on top and bottom of ramp?
Willing to consider any practical solutions.
RE: Texture of ADA Ramps
A review of Internet material still leaves much uncertainty.
Some sources (Caltrans)say tactile surface not needed on curb ramps, some say yes.
Found suppliers of concrete stampers, cast in place tile, and glue on s. Anybody have experience with these and are there reasons to choose one over the other for new ramps, or rehabbing ramps.
Your best bet is to go to the source: http://www.access-board.gov/indexes/accessindex.htm, which says:
4.7.7 Detectable Warnings. A curb ramp shall have a detectable warning complying with 4.29.2. The detectable warning shall extend the full width and depth of the curb ramp.
Section 4.29.2 says:
4.29.2* Detectable Warnings on Walking Surfaces. Detectable warnings shall consist of raised truncated domes with a diameter of nominal 0.9 in (23 mm), a height of nominal 0.2 in (5 mm) and a center-to-center spacing of nominal 2.35 in (60 mm) and shall contrast visually with adjoining surfaces, either light-on-dark, or dark-on-light.
The material used to provide contrast shall be an integral part of the walking surface. Detectable warnings used on interior surfaces shall differ from adjoining walking surfaces in resiliency or sound-on-cane contact.
I don't have any direct experience, but I'd guess the failure mechanism for stamped concrete would be spalling if poorly done, and the precast tiles and glued plastic may come up over time.
They list their site as WWW.NHDOT.COM
mpennengr
RIDOT
The glues ons were also tried but, unless the installation conditions are optimal, the glue lets go during winter snow and ice removal.
I work in southeast Iowa where conditions are very extreme. We work with highs of 110 in the summer to 40 below in the winter.
Interested in any field use results, good or bad. we are NE state with heavy public usage at our sites.
TrafficPro
At the PANYNJ we expect to be using COTE-L's newer product SAFTI-TRAX MAT, with the same adhesion material, and hope for similar results. Have not used other products, so cant comment on them.
Hope my research is of some use to anyone else interested
in the Detectable Warning Surface requirement.
The address I have for Dave Bizuga is David.Bizuga@DOT.STATE.NJ.US TEL 609 530 5273
TrafficPro
The ramps were installed in Chesterfield, Missouri (a suburb of St. Louis).
First off, thank you for the kind comments about Vanguard products. My response is not about Vanguard products. We're very proud of them, as we designed them based on the absolute, and consistant failure of every other product out there as pertaining to "detectable warnings".
The short version is, we were/are a local (Seattle) company that was asked to install detectable warnings (prior to the suspension in 1994...released in July 2001). Our frustration was that everything that was available....turned out to have any number of flaws (peeling, chipping, fading....ad nauseum).
Today we are a national company providing non skid (not "slip resistant") detectable warning products in every state, through licensed applicators (see "stadry" comments above).
This remains true today.
That is the end of my "Vanguard is better" speech.
Now, on to the comments...in sequence:
trafficPro:
"The Buttons"...are required (ADAAG 4.29.2 is the law...other options simply don't exist)....and there IS an easier way (one in which I'm not allowed on this forum to promote...however...I suspect you can find me).
Your concerns about womens heels are valid....that is only ONE of the issues with grooves.
Aside from the fact that grooves are not detectable....they hold water...grow moss...it's simply a bad move.
Moreover...it won't meet any standard of detectability.
Remember...the ADA states clearly....any exterior ramp that is designed, built or formed such that it "holds or retains water" is unnacceptable (as per ADAAG)...ergo...any surface texture that does so...is verbotten.
LTAPPJim:
He is correct (see above). By the way...the list of detectable warning suppliers can be found at "http://www.access-board.gov/"
trafficPro:
Keep in mind...DOT/FHWA has/have made clear...the only acceptable "texture" is truncated domes (kinda like Ford when he said in the early 1900's..."you can have any color you want...so long as it's black")..in short...the only acceptable texture for "detectable warnings" is....truncated domes.
Cincinnati has stated that stamped truncated domes won't fly (and are not acceptable)...they have also alluded to that "glue down" tiles are also not acceptable. New Mexico has rigorously stated similar sections...as have several other states.
Injection molded tiles just don't work.
Truncated domes ("detectable warnings") are now required on public and private ramps....full width and depth on ramps, 36 inches on "Hazardous vehicular ways", and 24 inches on DOT/FHWA sites (cities/municipalities, etc.).
Be aware...the Federal Access Board has stated...through "Equivalent Facilitation"...the 24 inch standard is acceptable (in lieu of all other standards)...but further..they have stated that they do not have the authority to mandate same....DOJ does.
DOJ has told me verbally that they would (and do) approve this design change as equivalent to all previous (4.29.2) designs.
They won't however put it in writing.
Safe bet: Full width and depth on ramps, 36 inches on hazardous vehicular ways.
If, however, you want to serve the blind and visually impaired community well....use 24 inches (see PROWAAC re: "vibratory zone"). "Equivalent Facilitation" allows this. (It is also preferred by all agencies).
GeoPaveTraffic:
See me. I have photos of this product fading in less than 16 months (in Seattle...kinda rainy there)...and once fade begins..it's exponential.
COLDDAVE:
I have what you need.
trafficPro:
They all fail. I wish I could tell you otherwise...but...they simply don't work.
I have a better plan.
(See comments above re: Virginia rail from "stadry").
trafficPro:
COTE-L....I like this product....I actually like it a lot...however, the April 6, 2002 Draft final from the federal access board states that you cannot paint detectable warnings to cause them to meet the visual contrast.
COTE-L's surface coloring is not a paint...but it's not "integral" as required. This causes the surface to need recoating on an ongoing basis. The ADA states (I'll paraphrase since I don't have the docs in front of me) that "all ADA installations MUST be maintained in 'as installed condition'".....clearly....no one wants a system that requires the city of.....or the county of.....to have to schedule maint.
(I know of a system wherein which this is not required....and...if you email me...I'll tell you what it is).
There ya have it...thanks for allowing me to comment.
http://www.jamsafety.com
See us at www.ADATiles.com
We produce products for both fresh pour concrete, as well as a flush mount product for retrofitting previously completed projects.
