Adopting USB2Wiggler hardware
There is used USB2Wiggler device for OnCE interface, it has small internal daughter board labeled COP-OnCE that adapts it to a ONCE pinout. I wanna know is it possible to adopt this USB2Wiggler hardware for ARM and MIPS JTAG interfaces.
Can this hardware be configured for JTAG debugging interface by opening the cover, removing the "COP-OnCE" adapter PCB, and putting the target ribbon cable on P6 or P4? (20 or 14 pin JTAG) Can hardware also be used for MIPS interface by connecting cable to P4?
Here is pictures.
http://www.macraigor.com/downloads/usbDemon_manual...
Target cable pinouts:
http://www.macraigor.com/downloads/pinouts.pdf
Here is pictures.
RE: Adopting USB2Wiggler hardware
I'd start with your JTAG software (running on your PC or laptop) and see what the associated documentation calls up; what cable/hardware does it need? It might be a lot simpler than what you're contemplating.
Dan - Owner
http://www.Hi-TecDesigns.com
Dan - Owner
