Gearmotor Clutch to protect output gear
Any suggestions for a simple clutch to protect an output gear from self destruction? A gearmotor can generate 2-3 times the published stall torque depending on the dynamics of the system.
RE: Gearmotor Clutch to protect output gear
Application: automotive, comm'l
output of the motor? Is it hydraulic,
electric or ? I think this would be
a cheaper solution.
- Gear on shaft with collar; belleville spring behind it with adj nut. A little complex but compact.
- A one way ratchet clutch made from plastic. The tapered fingers were acetal. A two way clutch could be made the same way by changing 90 deg stops to 45 deg.
- USA Tolerance Rings (dot com) is showing a tolerance ring for limited slip gears on shafts. The mfr says that it has to be developed on an individual basis.
Any other ideas for simple clutches?
