EN Pressure Plate Designation Meaning? E.g. P460NL,vs P460NJ2 etc
Dear Sir,
Could anyone enlighten me on the subject of plate designation for EN plates?
I understand from EN 10027-1 the following:
For example: P460NL
-P: Pressure
-460: Mechanical property value
-N: Normalized
-L: Low temperature
However, I could not find what are the meanings of designations such as J2, J4.
Thank you for your help.
For example: P460NL
-P: Pressure
-N: Normalized
-L: Low temperature
RE: EN Pressure Plate Designation Meaning? E.g. P460NL,vs P460NJ2 etc
J: 27J - K: 40J - L: 60J
R: room temp - 0: 0° celcius - 2: minus 20 °C - 4: minus 40°C
J2: at least 27J @ minus 20°C
Can be found in EN10025 or EN10027, will check this evening.
edit:
file attached
as found in the EN10027-1
so here it is...
kingnero is correct.
