ABAQUS without GUI
ABAQUS without GUI
ABAQUS without GUI
Hi all,
I am wondering if it saves time to run jobs in ABAQUS in a non GUI environment.
If yes, can I run the script I'm using in the GUI to create and run my models?
If yes again, how do I do it?
Thanks a lot in advance!
RE: ABAQUS without GUI
I'm not sure if it will save you any time, but you can submit the jobs via the command line. All you need is the input (.inp) file. If you google "Abaqus command line" you should find everything you need.
Good luck,
Dave
You can run a script from command line with a "noGUI" flag. Section 3.2.6 of the Analysis User's Manual (6.14).
