Casting dwg by NX
Casting dwg by NX
Dear Friends,
I am new to NX having 1 year of experience,here is the attached Section dwg having different crossection on bot[b]h sides, Can you please suggust me how to solve this in NX (By which method or by using which command),
Thank u.
Thank u.
Powdan Jain.
RE: Casting dwg by NX
I understand nothing of this.
Is it the cut which is different or is it the hatching ?
more images needed.
Tomas
www.nxjournaling.com
To me it looked like a flanged fitting/valve ...although as experts already stated more information is required i think this model will take some more steps rather than just a revolve command.
The middle portion might take a ruled (or lofted ) profile with different sections (the front portion is not shown in the image.
Best Regards
Kapil
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
Now i am attaching the dwg with more details, pl let me know by how to solve the part dwg (by using which command and how,
Kindly do the needful.
Powdan Jain.
You can get some valve models from Grab Cad and it will help you visualize the model correctly.
Kapil
is it rectangular / circular/elliptical etc. Somebody has drawn , in 2D, 2 views and the moldmaker will have to do the thinking about how the shapes come together. ( -and eventually get spanked because his thoughts were different.)
I still don't understand what it is that you want to do, or want our help with.
build the model ?
create the drawing?
create a section view ?
What version of NX do you use ?
Tomas
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Powdan Jain.
