The effective length of strut in a X- Bracing
In a X-brace , is it possible to take advantage of tension member countering the buckling of compression member ?
In that case is thee any literature or paper wherein this is quantified in numerical terms.
RE: The effective length of strut in a X- Bracing
Am I correct in assuming that K is applicable to the full diagonal rather than half the diagonal.
For e.g if the brace frame is 10 x 10 square then effective length will be 0.7 x diagonal = 0.7 x sqrt(2)*10 = .7 x 1.42 x 10
This has the effect of reducing the lateral bracing ability of the tension brace on the compression brace.
