how do I make an animated living hinge?
I'm new to SolidWorks and am fumbling my way through. My most recent problem is that I need to create 3-d models of plastic living hinges. Is there a way to create a working (animated) living hinge with SolidWorks?
RE: how do I make an animated living hinge?
You could also cheat, and create a 2 part assembly of your hinged part, to simulate a living hinge for "shown-n-tell".
"The attempt and not the deed confounds us."
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
ô¿ô
the solid version can be used to make the mold while the moving "cut" version is a good visual to show a client how it will move. Thanks for all responses they are appreciated.
ò¿~
