Pneumatic Test on compartment of FRT
Dear Tank Builders,
API 650 appendix C requires pneumatic test on each compartment of FRT. There is also other alternative i.e. vacuum box and penetrating oil.
Is there any guidance how much pressure for this pneumatic test ? I believe the number should come from the tank designer.
Please share to me if you have this experience including the procedure in your previous or current project.
Syah
Syah
