Undo last zoom
Undo last zoom
Undo last zoom
Does catia have a undo last zoom command? That is very useful when one has to zoom in to pick up some small feature, and then get back to the previous zoom. The simple undo last command does not help here.
RE: Undo last zoom
there is a command called "Previous view". It does stack several views...
create a new toolbar and insert this function into so you can access it rapidly, or you could assign a shortcut to it.
Eric N.
