NX10 solid selection display problem
Hi All,
running NX10.0.2.6
In NX10 when I select a solid that has offset faces I'm seeing the original solid (transparent) before offset along with the new solid. If I remove the parameters it stops, also if I change some of the layers (not the one the solid is on) it sometimes stops displaying the original solid along with the new. Is this behavior normal? It does not do this in NX9. Would like it to work like NX9.
Any help to shut this off would be appreciated,
Rick D
running NX10.0.2.6
Rick D
Win7 64 bit w/NX9.0.3.4 MP9 and NX10.0.2
Vericut 7.4
RE: NX10 solid selection display problem
www.nxjournaling.com
As cowski stated the HIGHLIGHT ORIGINAL setting needs to be off (the preference location remains same in NX10 as in NX9).
Attached is a picture.
Kapil
Sincerely,
Rick D.
Vericut 7.4
