bounding box scrip problem
hello, everybody!
I`ve tried to use script from CATIA_Portable_Script_Center_v2.0 wich is called "BoundingBox.CATScript" BUT always have eror in this line
I found closed thread http://www.eng-tips.com/viewthread.cfm?qid=353951
where this issue have been disscused by @puk and @ferdo
guys if someone of you know what is te solvetion, please let me know.
I`ve tried at R20 and R24
P.S. maybe already exist adaptation for R24?
Set hybridBodies1 = body1.HybridBodies
Set hybridBody1 = hybridBodies1.Add
hybridBody1.Name = "definition_points"
RE: bounding box scrip problem
That line is trying to make a geoset in a body. What is body1 set as? If you could include the rest of the code above it would be helpful.
lardman363 here the full code from CATIA_Portable_Script_Center_v2.0
CODE -->
'--------------------------------------------------------'bib 23-07-2003 'creation of the bounding box with 0mm offset on each face 'the document must be a catpart 'inputs: ' - a local axis ' - a surface ' - macro modified by ferdo '-------------------------------------------------------- Sub CATMain() 'declaration des variables CATIA.DisplayFileAlerts = False Dim Message, Style, Title, Response, MyString Message = ("This macro will find the bounding box of a solid or a JOINED Surface with 0mm offset on each face" &_ (chr(13)) &_ " - The active document must be a CATPart"&_ (chr(13)) &_ " - A local Axis will be created automatically"&_ (chr(13)) &_ " - The dimensions of the bounding box will be saved in a file"&_ (chr(13)) &_ ""&(chr(13))&_ " Do you want to continue ?") Style = vbYesNo + vbDefaultButton2 'Define buttons. Title = "Purpose " Response = MsgBox(Message, Style, Title) If Response = vbYes Then ' User chose Yes. MyString = "Yes" '///////////////////////////////////// inserting an axis system Dim partDocument2 As Document Set partDocument2 = CATIA.ActiveDocument Dim part2 As Part Set part2 = partDocument2.Part Dim axisSystems1 As AxisSystems Set axisSystems1 = part2.AxisSystems Dim axisSystem1 As AxisSystem Set axisSystem1 = axisSystems1.Add() axisSystem1.OriginType = catAxisSystemOriginByCoordinates Dim arrayOfVariantOfDouble1(2) arrayOfVariantOfDouble1(0) = 0.000000 arrayOfVariantOfDouble1(1) = 0.000000 arrayOfVariantOfDouble1(2) = 0.000000 axisSystem1.PutOrigin arrayOfVariantOfDouble1 axisSystem1.XAxisType = catAxisSystemAxisByCoordinates Dim arrayOfVariantOfDouble2(2) arrayOfVariantOfDouble2(0) = 1.000000 arrayOfVariantOfDouble2(1) = 0.000000 arrayOfVariantOfDouble2(2) = 0.000000 axisSystem1.PutXAxis arrayOfVariantOfDouble2 axisSystem1.YAxisType = catAxisSystemAxisByCoordinates Dim arrayOfVariantOfDouble3(2) arrayOfVariantOfDouble3(0) = 0.000000 arrayOfVariantOfDouble3(1) = 1.000000 arrayOfVariantOfDouble3(2) = 0.000000 axisSystem1.PutYAxis arrayOfVariantOfDouble3 axisSystem1.ZAxisType = catAxisSystemAxisByCoordinates Dim arrayOfVariantOfDouble4(2) arrayOfVariantOfDouble4(0) = 0.000000 arrayOfVariantOfDouble4(1) = 0.000000 arrayOfVariantOfDouble4(2) = 1.000000 axisSystem1.PutZAxis arrayOfVariantOfDouble4 part2.UpdateObject axisSystem1 axisSystem1.IsCurrent = True part2.Update Dim settingControllers1 As SettingControllers Set settingControllers1 = CATIA.SettingControllers Dim visualizationSettingAtt1 As SettingController Set visualizationSettingAtt1 = settingControllers1.Item("CATVizVisualizationSettingCtrl") visualizationSettingAtt1.SaveRepository '/////////////////////////////////////////////// start bounding box Dim axis Dim remake Dim partDocument1 As PartDocument Dim part1 As Part dim axisref as reference Dim ShapeFactory1 as ShapeFactory Dim hybridShapeFactory1 As HybridShapeFactory Dim sStatus As String Dim hybridShapeD1 , hybridShapeD2 ,hybridShapeD3 As HybridShapeDirection Dim Default, a1,a2,a3,a4,a5,a6 'servent au changement des dimensions de la box Dim bodies1 As Bodies Dim body1 As Body Dim reference1 As Reference 'la shape Dim HybridShapeExtremum1 ,HybridShapeExtremum2 ,HybridShapeExtremum3 As HybridShapeExtremum Dim HybridShapeExtremum4 ,HybridShapeExtremum5 ,HybridShapeExtremum6 As HybridShapeExtremum Dim originCoord(2) Set partDocument1 = CATIA.ActiveDocument If (Instr(partDocument1.Name,".CATPart"))<> 0 Then Set part1 = partDocument1.Part Set Selection = partDocument1.Selection part1.Update Set hybridShapeFactory1 = part1.HybridShapeFactory ReDim sFilter(0) Msgbox "Select a local axis " sFilter(0) = "AxisSystem" sStatus = Selection.SelectElement2(sFilter, "select a local axis", False) dim axiscoord(2) dim axissyst Set axissyst = Selection.Item(1).value set axisref= Selection.Item(1).value ref_name_systaxis = axissyst.Name axissyst.IsCurrent = 1 axissyst.name ="gertrude.toto" axname = axissyst.Name dim originpoint as HybridShapePointCoord axisSyst.GetOrigin originCoord set originpoint= hybridShapeFactory1.AddNewPointCoord(originCoord(0) ,originCoord(1) ,originCoord(2) ) set axisref = Part1.CreateReferenceFromObject (originpoint) axissyst.GetXAxis AxisCoord Set hybridShapeD1 = hybridShapeFactory1.AddNewDirectionByCoord(AxisCoord(0), AxisCoord(1), AxisCoord(2)) axissyst.GetYAxis AxisCoord Set hybridShapeD2 = hybridShapeFactory1.AddNewDirectionByCoord(AxisCoord(0), AxisCoord(1), AxisCoord(2)) axissyst.GetZAxis AxisCoord Set hybridShapeD3 = hybridShapeFactory1.AddNewDirectionByCoord(AxisCoord(0), AxisCoord(1), AxisCoord(2)) dim Plane_line_1 as hybridshapelineptdir set Plane_line_1=hybridShapeFactory1.addnewlinePtDir(originpoint,hybridShapeD1,0,0,false) dim Plane_line_2 as hybridshapelineptdir set Plane_line_2=hybridShapeFactory1.addnewlinePtDir(originpoint,hybridShapeD2,0,0,false) Selection.Clear Set partDocument1 = CATIA.ActiveDocument Set part1 = partDocument1.Part Dim oBodies As Bodies Set oBodies = Part1.Bodies Dim j As Integer j = oBodies.Count Set bodies1 = part1.Bodies Set body1 = bodies1.Add() body1.name="Boundingbox." & j Set hybridBodies1 = body1.HybridBodies Set hybridBody1 = hybridBodies1.Add hybridBody1.Name = "definition_points" 'demande a l'utilisateur de selectionner la face ReDim sFilter(0) Msgbox "Select a Face " sFilter(0) = "Face" sStatus = Selection.SelectElement2(sFilter, "select a face", False) If (sStatus = "Cancel") Then Exit Sub End If Set reference1= Selection.Item(1).Value dim hybridShapeExtract1 as HybridShapeExtract Set hybridShapeExtract1 = hybridShapeFactory1.AddNewExtract(reference1) hybridShapeExtract1.PropagationType = 1 hybridShapeExtract1.ComplementaryExtract = False hybridShapeExtract1.IsFederated = False set reference1 = hybridShapeExtract1 'creation des 6 points extremums de la shape selectionnA©e Set HybridShapeExtremum1 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD1, 1) Set HybridShapeExtremum2 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD1, 0) Set hybridShapeExtremum3 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD2, 1) Set hybridShapeExtremum4 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD2, 0) Set hybridShapeExtremum5 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD3, 1) Set hybridShapeExtremum6 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD3, 0) part1.Update 'on se met dans l'open body "def_points" Dim hybridBody2 As HybridBody Set hybridBody2 = hybridBodies1.Item("definition_points") hybridBody2.AppendHybridShape HybridShapeExtremum1 part1.InWorkObject = HybridShapeExtremum1 HybridShapeExtremum1.Name = "max_X" hybridBody2.AppendHybridShape HybridShapeExtremum2 part1.InWorkObject = HybridShapeExtremum2 HybridShapeExtremum2.Name = "min_X" hybridBody2.AppendHybridShape hybridShapeExtremum3 part1.InWorkObject = hybridShapeExtremum3 hybridShapeExtremum3.Name = "max_Y" hybridBody2.AppendHybridShape hybridShapeExtremum4 part1.InWorkObject = hybridShapeExtremum4 hybridShapeExtremum4.Name = "min_Y" hybridBody2.AppendHybridShape hybridShapeExtremum5 part1.InWorkObject = hybridShapeExtremum5 hybridShapeExtremum5.Name = "max_Z" hybridBody2.AppendHybridShape hybridShapeExtremum6 part1.InWorkObject = hybridShapeExtremum6 hybridShapeExtremum6.Name = "min_Z" part1.update 'creation des points aux meme coordonnees que les extremums Dim Ref1 as reference Set Ref1 = part1.CreateReferenceFromObject(HybridShapeExtremum1) Dim Point1 As HybridShapePointCoord Set Point1 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref1) hybridBody2.AppendHybridShape Point1 set point_ref11=part1.CreateReferenceFromObject(Point1) Dim Ref2 As Reference Set Ref2 = part1.CreateReferenceFromObject(HybridShapeExtremum2) Dim Point2 As HybridShapePointCoord Set Point2 = hybridShapeFactory1.AddNewPointCoordWithReference(0,0 , 0, Ref2) hybridBody2.AppendHybridShape Point2 set point_ref12=part1.CreateReferenceFromObject(Point2) Dim Ref3 As Reference Set Ref3 = part1.CreateReferenceFromObject(HybridShapeExtremum3) Dim Point3 As HybridShapePointCoord Set Point3 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref3) hybridBody2.AppendHybridShape Point3 set point_ref13=part1.CreateReferenceFromObject(Point3) Dim Ref4 As Reference Set Ref4 = part1.CreateReferenceFromObject(HybridShapeExtremum4) Dim Point4 As HybridShapePointCoord Set Point4 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref4) hybridBody2.AppendHybridShape Point4 set point_ref14=part1.CreateReferenceFromObject(Point4) Dim Ref5 As Reference Set Ref5 = part1.CreateReferenceFromObject(HybridShapeExtremum5) Dim Point5 As HybridShapePointCoord Set Point5 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref5) hybridBody2.AppendHybridShape Point5 set point_ref5=part1.CreateReferenceFromObject(Point5) Dim Ref6 As Reference Set Ref6 = part1.CreateReferenceFromObject(HybridShapeExtremum6) Dim Point6 As HybridShapePointCoord Set Point6 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref6) hybridBody2.AppendHybridShape Point6 set point_ref6= part1.CreateReferenceFromObject(Point6) ' Update pour les points avant creation du skrtch (12/09/2003) part1.update ' Fin Update axissyst.IsCurrent = 1 'creation d'un sketch Set sketches1 = hybridBody1.HybridSketches Set reference_axis_syst = part1.CreateReferenceFromName("Selection_RSur:(Face:(Brp:(gertrude.toto;1);None:());gertrude.toto)") Set standard_body_sketch1 = sketches1.Add(reference_axis_syst) Set factory2D1 = standard_body_sketch1.OpenEdition() Set geometricElements1 =standard_body_sketch1.GeometricElements Set axis2D1 = geometricElements1.Item("AbsoluteAxis") Set line_HDirection = axis2D1.GetItem("HDirection") line_HDirection.ReportName = 1 Set line_VDirection = axis2D1.GetItem("VDirection") line_VDirection.ReportName = 2 'Creation d'un carrA© dans le sketch ponto = 20000 Set point_ref_1 = factory2D1.CreatePoint(-ponto, -ponto) point_ref_1.ReportName = 3 Set point_ref_2 = factory2D1.CreatePoint(ponto, -ponto) point_ref_2.ReportName = 4 Set point_ref_3 = factory2D1.CreatePoint(ponto, ponto) point_ref_3.ReportName = 5 Set point_ref_4 = factory2D1.CreatePoint(-ponto, ponto) point_ref_4.ReportName = 6 Set line_ref_1_2 = factory2D1.CreateLine(-ponto, -ponto, ponto, -ponto) line_ref_1_2.ReportName = 7 line_ref_1_2.StartPoint = point_ref_1 line_ref_1_2.EndPoint = point_ref_2 Set line_ref_2_3 = factory2D1.CreateLine(ponto, -ponto, ponto, ponto) line_ref_2_3.ReportName = 8 line_ref_2_3.StartPoint = point_ref_2 line_ref_2_3.EndPoint = point_ref_3 Set line_ref_3_4 = factory2D1.CreateLine(-ponto, ponto, ponto, ponto) line_ref_3_4.ReportName = 9 line_ref_3_4.StartPoint = point_ref_4 line_ref_3_4.EndPoint = point_ref_3 Set line_ref_4_1 = factory2D1.CreateLine(-ponto, -ponto, -ponto, ponto) line_ref_4_1.ReportName = 10 'line_ref_4_1.Construction = True line_ref_4_1.StartPoint = point_ref_1 line_ref_4_1.EndPoint = point_ref_4 'Referencement et creation des contraintes Set reference_line_ref_1_2 = part1.CreateReferenceFromObject(line_ref_1_2) Set reference_line_ref_2_3 =part1.CreateReferenceFromObject(line_ref_2_3) Set reference_line_ref_3_4 =part1.CreateReferenceFromObject(line_ref_3_4) Set reference_line_ref_4_1 =part1.CreateReferenceFromObject(line_ref_4_1) Set electrode_constraints = standard_body_sketch1.Constraints ' Modif de la refrence des points du 12/09/2003) Set constraint_toto_2 = electrode_constraints.AddBiEltCst(catCstTypeDistance,point_ref11, reference_line_ref_2_3) Set constraint_toto_3 = electrode_constraints.AddBiEltCst(catCstTypeDistance, point_ref13, reference_line_ref_3_4) Set constraint_toto_4 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref_4_1, point_ref12) Set constraint_toto_1 = electrode_constraints.AddBiEltCst(catCstTypeDistance,reference_line_ref_1_2, point_ref14 ) 'Fin modif Dim length1 As Dimension Set length1 =constraint_toto_1.Dimension length1.Value = 0 Dim length2 As Dimension Set length2 =constraint_toto_2.Dimension length2.Value = 0 Dim length3 As Dimension Set length3 =constraint_toto_3.Dimension length3.Value = 0 Dim length4 As Dimension Set length4 =constraint_toto_4.Dimension length4.Value = 0 standard_body_sketch1.closeEdition() part1.update '---------------------------------------------------------------------------------------------------------------------------------- 'creation des plans infA©rieur et superieur matches sur les extremums '---------------------------------------------------------------------------------------------------------------------------------- dim plan_inferieur as hybridshapeplaneoffsetpt dim plan_origin as hybridshapePlanes2lines dim Origin_line_1 as reference set Origin_line_1 = part1.createreferencefromobject(line_HDirection) dim Origin_line_2 as reference set Origin_line_2 = part1.createreferencefromobject(line_VDirection) set plan_origin = hybridShapeFactory1.addnewplane2lines(Origin_line_1,Origin_line_2) dim ref_plan_origin as reference set ref_plan_origin = part1.createreferencefromobject(plan_origin) Set Ref6 = part1.CreateReferenceFromObject(HybridShapeExtremum6) set plan_inferieur=hybridshapefactory1.addnewplaneOffsetPt(ref_plan_origin,point_ref6) hybridBody2.AppendHybridShape plan_inferieur part1.InWorkObject = plan_inferieur dim plan_superieur as hybridshapeplaneoffsetpt Set Ref5 = part1.CreateReferenceFromObject(HybridShapeExtremum5) set plan_superieur=hybridshapefactory1.addnewplaneOffsetPt(ref_plan_origin,point_ref5) hybridBody2.AppendHybridShape plan_superieur part1.InWorkObject = plan_superieur part1.Update '---------------------------------------------------------------------------------------------------------------------------------- 'creation des plans infA©rieur et superieur offsetes '---------------------------------------------------------------------------------------------------------------------------------- Dim Point_inf As HybridShapePointCoord Set Point_inf = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, point_ref6) hybridBody2.AppendHybridShape Point_inf dim ref_point_inf as reference set ref_point_inf =part1.createreferencefromobject(Point_inf) 'projection du point inferieur sur le plan superieur dim proj_pt_inf as hybridshapeproject set proj_pt_inf = hybridshapefactory1.addnewproject(point_ref6, plan_superieur ) hybridBody2.AppendHybridShape proj_pt_inf part1.InWorkObject = proj_pt_inf Dim Point_sup As HybridShapePointCoord Set Point_sup= hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, proj_pt_inf) hybridBody2.AppendHybridShape Point_sup dim ref_point_sup as reference set ref_point_sup =part1.createreferencefromobject(Point_sup) dim line_guide as hybridshapelineptpt set line_guide=hybridshapefactory1.addnewlineptpt( ref_point_sup,ref_point_inf) hybridBody2.AppendHybridShape line_guide part1.InWorkObject = line_guide set ref_guideline =part1.createreferencefromobject(line_guide) dim oStart as length set oStart=line_guide.beginoffset oStart.value =0 dim oEnd as length set oEnd=line_guide.endoffset oEnd.value =0 Set constraints_for_z = part1.Constraints Set constraint_dz =constraints_for_z.AddMonoEltCst(catCstTypeLength,ref_guideline ) set length_dz= constraint_dz.Dimension part1.update '---------------------------------------------------------------------------------------------------------------------------------- 'creation second sketch '---------------------------------------------------------------------------------------------------------------------------------- Set sketches2 = hybridBody1.HybridSketches Set standard_body_sketch2 = sketches2.Add(plan_inferieur) Set factory2D2 = standard_body_sketch2.OpenEdition() Set geometricElements2 =standard_body_sketch2.GeometricElements Set axis2D1 = geometricElements1.Item("AbsoluteAxis") 'Creation d'un carrA© dans le sketch pont = 200000 Set point_ref1_1 = factory2D2.CreatePoint(-pont, -pont) Set point_ref1_2 = factory2D2.CreatePoint(pont, -pont) Set point_ref1_3 = factory2D2.CreatePoint(pont, pont) Set point_ref1_4 = factory2D2.CreatePoint(-pont, pont) Set line_ref1_1_2 = factory2D2.CreateLine(-pont, -pont, pont, -pont) line_ref1_1_2.StartPoint = point_ref1_1 line_ref1_1_2.EndPoint = point_ref1_2 Set line_ref1_2_3 = factory2D2.CreateLine(pont, -pont, pont, pont) line_ref1_2_3.StartPoint = point_ref1_2 line_ref1_2_3.EndPoint = point_ref1_3 Set line_ref1_3_4 = factory2D2.CreateLine(-pont, pont, pont, pont) line_ref1_3_4.StartPoint = point_ref1_4 line_ref1_3_4.EndPoint = point_ref1_3 Set line_ref1_4_1 = factory2D2.CreateLine(-pont, -pont, -pont, pont) line_ref1_4_1.StartPoint = point_ref1_1 line_ref1_4_1.EndPoint = point_ref1_4 'Referencement et creation des contraintes Set reference_line_ref1_1_2 =part1.CreateReferenceFromObject(line_ref1_1_2) Set reference_line_ref1_2_3 =part1.CreateReferenceFromObject(line_ref1_2_3) Set reference_line_ref1_3_4 =part1.CreateReferenceFromObject(line_ref1_3_4) Set reference_line_ref1_4_1 =part1.CreateReferenceFromObject(line_ref1_4_1) Set reference_line_ref_1_2 =part1.CreateReferenceFromObject(line_ref_1_2) Set reference_line_ref_2_3 =part1.CreateReferenceFromObject(line_ref_2_3) Set reference_line_ref_3_4 =part1.CreateReferenceFromObject(line_ref_3_4) Set reference_line_ref_4_1 =part1.CreateReferenceFromObject(line_ref_4_1) set proj_1_2 = factory2D2.CreateProjection(reference_line_ref_1_2) set proj_2_3 = factory2D2.CreateProjection(reference_line_ref_2_3) set proj_3_4= factory2D2.CreateProjection(reference_line_ref_3_4) set proj_4_1 = factory2D2.CreateProjection(reference_line_ref_4_1) set ref_line_sk1_1_2=part1.createreferencefromobject(proj_1_2) set ref_line_sk1_2_3=part1.createreferencefromobject(proj_2_3) set ref_line_sk1_3_4=part1.createreferencefromobject(proj_3_4) set ref_line_sk1_4_1=part1.createreferencefromobject(proj_4_1) Set electrode_constraints = standard_body_sketch2.Constraints Set constraint_toto_11 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref1_1_2, ref_line_sk1_1_2) Set constraint_toto_12 = electrode_constraints.AddBiEltCst(catCstTypeDistance, ref_line_sk1_2_3, reference_line_ref1_2_3) Set constraint_toto_13 = electrode_constraints.AddBiEltCst(catCstTypeDistance, ref_line_sk1_3_4, reference_line_ref1_3_4) Set constraint_toto_14 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref1_4_1,ref_line_sk1_4_1 ) 'Dim length11 As Dimension Set length11 =constraint_toto_11.Dimension length11.Value = 0 Dim length12 As Dimension Set length12 =constraint_toto_12.Dimension length12.Value = 0 Dim length13 As Dimension Set length13 =constraint_toto_13.Dimension length13.Value = 0 Dim length14 As Dimension Set length14 =constraint_toto_14.Dimension length14.Value = 0 standard_body_sketch2.closeEdition() part1.update '---------------------------------------------------------------------------------------------------------------------------------- 'creation third sketch '---------------------------------------------------------------------------------------------------------------------------------- Set sketches3 = hybridBody1.HybridSketches Set standard_body_sketch3 = sketches3.Add(plan_inferieur) Set factory2D3 = standard_body_sketch3.OpenEdition() Set geometricElements3 =standard_body_sketch3.GeometricElements Set axis2D1 = geometricElements1.Item("AbsoluteAxis") 'Referencement et creation des contraintes Set reference_line_ref1_1_2 =part1.CreateReferenceFromObject(line_ref1_1_2) Set reference_line_ref1_2_3 =part1.CreateReferenceFromObject(line_ref1_2_3) Set reference_line_ref1_3_4 =part1.CreateReferenceFromObject(line_ref1_3_4) Set reference_line_ref1_4_1 =part1.CreateReferenceFromObject(line_ref1_4_1) set proj1_1_2 = factory2D3.CreateProjection(reference_line_ref1_1_2) set proj1_2_3 = factory2D3.CreateProjection(reference_line_ref1_2_3) set proj1_3_4= factory2D3.CreateProjection(reference_line_ref1_3_4) set proj1_4_1 = factory2D3.CreateProjection(reference_line_ref1_4_1) set ref_proj1_1_2 = part1.CreateReferenceFromObject(proj1_1_2) set ref_proj1_2_3 = part1.CreateReferenceFromObject(proj1_2_3) set ref_proj1_3_4= part1.CreateReferenceFromObject(proj1_3_4) set ref_proj1_4_1 = part1.CreateReferenceFromObject(proj1_4_1) set constraints_dim= standard_body_sketch3.constraints Set constraint_dx = constraints_dim.AddMonoEltCst(catCstTypeLength,ref_proj1_1_2 ) Set constraint_dy = constraints_dim.AddMonoEltCst(catCstTypeLength,ref_proj1_2_3 ) Set length_dx =constraint_dx.Dimension dx_value=length_dx.value Set length_dy=constraint_dy.Dimension dy_value=length_dy.value standard_body_sketch3.closeEdition() part1.update 'creation des 6 parametres pour changer la dimension dim string_1 as string string_1="Offset_Bbox_Max_X." & j dim string_2 as string string_2="Offset_Bbox_Min_X." & j dim string_3 as string string_3="Offset_Bbox_Max_Y." & j dim string_4 as string string_4="Offset_Bbox_Min_Y." & j dim string_5 as string string_5="Offset_Bbox_Max_Z." & j dim string_6 as string string_6="Offset_Bbox_Min_Z." & j dim string_7 as string string_7="Bbox_dx." & j dim string_8 as string string_8="Bbox_dy." & j dim string_9 as string string_9="Bbox_dz." & j Dim Offset_Bbox_Max_X As RealParam Set Offset_Bbox_Max_X = part1.Parameters.CreateDimension( string_1,"Length", 0) Dim Offset_Bbox_Min_X As RealParam Set Offset_Bbox_Min_X= part1.Parameters.CreateDimension( string_2,"Length", 0) Dim Offset_Bbox_Max_Y As RealParam Set Offset_Bbox_Max_Y= part1.Parameters.CreateDimension( string_3,"Length", 0) Dim Offset_Bbox_Min_Y As RealParam Set Offset_Bbox_Min_Y= part1.Parameters.CreateDimension( string_4,"Length", 0) Dim Offset_Bbox_Max_Z As RealParam Set Offset_Bbox_Max_Z= part1.Parameters.CreateDimension( string_5,"Length", 0) Dim Offset_Bbox_Min_Z As RealParam Set Offset_Bbox_Min_Z= part1.Parameters.CreateDimension( string_6,"Length", 0) Set Bbox_dx_hidden= part1.Parameters.CreateDimension(string_7,"Length",dx_value) Set Bbox_dy_hidden= part1.Parameters.CreateDimension(string_8,"Length",dy_value) Set Bbox_dz_hidden= part1.Parameters.CreateDimension(string_9, "Length",length_dz.value) Bbox_dx_hidden.hidden=True Bbox_dy_hidden.hidden=True Bbox_dz_hidden.hidden=True Set Bbox_dx= part1.Parameters.CreateDimension(string_7,"Length",0) Set Bbox_dy= part1.Parameters.CreateDimension(string_8,"Length",0) Set Bbox_dz= part1.Parameters.CreateDimension(string_9,"Length",0) 'creation des formules pour modifier les dimensions de la boite Dim Formula_1 As Formula Set Formula_1 = part1.Relations.CreateFormula ("formula_Bbox_1."& j, "",length14, "Offset_Bbox_Min_X." & j ) Dim Formula_2 As Formula Set Formula_2 = part1.Relations.CreateFormula ("formula_Bbox_2."& j, "",length12, "Offset_Bbox_Max_X."& j ) Dim Formula_3 As Formula Set Formula_3 = part1.Relations.CreateFormula ("formula_Bbox_4."& j, "",length11, "Offset_Bbox_Min_Y." & j ) Dim Formula_4 As Formula Set Formula_4 = part1.Relations.CreateFormula ("formula_Bbox_4."& j, "",length13, "Offset_Bbox_Max_Y."& j ) Dim Formula_5 As Formula Set Formula_5 = part1.Relations.CreateFormula ("formula_Bbox_5."& j, "",oEnd , " Offset_Bbox_Min_Z." & j ) Dim Formula_6 As Formula Set Formula_6 = part1.Relations.CreateFormula ("formula_Bbox_6."& j, "",oStart, " Offset_Bbox_Max_Z." & j ) Dim Formula_7 As Formula Set Formula_7 = part1.Relations.CreateFormula ("formula_Bbox_7."& j, "", Bbox_dx ,"Bbox_dx." & j & "+Offset_Bbox_Min_X." & j & "+Offset_Bbox_Max_X." & j &"-0mm") Dim Formula_8 As Formula Set Formula_8 = part1.Relations.CreateFormula ("formula_Bbox_8."& j, "", Bbox_dy ,"Bbox_dy." & j & "+Offset_Bbox_Min_Y." & j & "+Offset_Bbox_Max_Y." & j &"-0mm") Dim Formula_9 As Formula Set Formula_9 = part1.Relations.CreateFormula ("formula_Bbox_9."& j, "", Bbox_dz ,"Bbox_dz." & j & "+Offset_Bbox_Min_Z." & j & "+Offset_Bbox_Max_Z." & j &"-0mm") '--------------------------------------------------------'creation sweep '-------------------------------------------------------- set sweepref_1 = part1.createreferencefromobject(standard_body_sketch3 ) set guide1 = part1.createreferencefromobject(line_guide ) Dim sweep1 as HybridShapeSweepExplicit set sweep1 =hybridShapeFactory1.AddNewSweepExplicit(sweepref_1,guide1 ) hybridBody2.AppendHybridShape sweep1 part1.InWorkObject = sweep1 part1.update 'creation de la closed surface Set shapeFactory1 = part1.ShapeFactory Set hybridBodies1 = body1.HybridBodies Set hybridBody1 = hybridBodies1.Item("definition_points") Dim hybridShapes1 As HybridShapes Set hybridShapes1 = hybridBody1.HybridShapes Dim refer1 As Reference Set refer1 = part1.CreateReferenceFromObject(sweep1) Dim closeSurface1 As CloseSurface Set closeSurface1 = shapeFactory1.AddNewCloseSurface(refer1 ) closeSurface1.name = "BoundingBox" part1.Update selection.Clear selection.Add(hybridBody1) selection.VisProperties.SetShow catVisPropertyNoShowAttr selection.Clear selection.Add(Body1) selection.VisProperties.SetRealColor 255,255,128,0 selection.visProperties.SetRealOpacity 150,1 selection.Visproperties.SetRealWidth 4,1 part1.Update axissyst.Name=ref_name_systaxis else Msgbox "The active document must be a CATPart" end if Else ' User chose No. MyString = "No" End If '//////////////////////////////// write dimensions to file Dim catDoc As PartDocument Dim catPart As Part Set catDoc=CATIA.ActiveDocument Set catPart=catDoc.Part Dim Bbox_dx As String Bbox_dx=catPart.Parameters.Item("Bbox_dx.1").ValueAsString 'MsgBox "Bbox_dx =" & Bbox_dx Dim Bbox_dy As String Bbox_dy=catPart.Parameters.Item("Bbox_dy.1").ValueAsString 'MsgBox "Bbox_dy =" & Bbox_dy Dim Bbox_dz As String Bbox_dz=catPart.Parameters.Item("Bbox_dz.1").ValueAsString 'MsgBox "Bbox_dz =" & Bbox_dz '--------------------------------------------------------' The location of the result file '--------------------------------------------------------Dim filename As String filename = CATIA.FileSelectionBox("Where do you want to save the result file", "*.txt", CatFileSelectionModeSave) Set Datos = CATIA.FileSystem.CreateFile(filename & ".txt" , True) Set ostream = Datos.OpenAsTextStream("ForAppending") 'Writes heading: sDateTime = CStr(Date) + Chr(32) + CStr(time) oStream.Write(sDateTime + sLF & Chr(10)) ostream.Write ("Bbox_dx =" & Bbox_dx & Chr(10)) ostream.Write ("Bbox_dy =" & Bbox_dy & Chr(10)) ostream.Write ("Bbox_dz =" & Bbox_dz & Chr(10)) End SubRE: bounding box scrip problem
CODE --> vba
'Copyright 2008 by Milton R. Hartung, Kamco Industries, Inc. (MiltonRH@kamcoind.com) 'Released under a creative commons Attribution-ShareAlike 3.0 license (http://creativecommons.org/licenses/by-sa/3.0/) ' 'code modified from bib or solid7 from http://2htts.com/CATBlog/index.php?itemid=24 'Creates a solid bounding box around a solid or surface, with the option to set offset on each face 'The document must be a CATPart 'Inputs: ' - an Axis System ' - A Face (Solid/Joined Surf will be chosen based on selection) '---------------------------------------------------------------------------------------------------------------------------------- Sub CATMain() 'Make sure they have axis ready and want to start CATIA.DisplayFileAlerts = False Dim Message, Style, Title, Response, MyString Message = ("This macro will create a solid bounding box around a solid or a joined surface, using an axis system. For useful results," & _ (Chr(13)) & _ "the axis should be based on some tooling directions, or created from the Measure Inertia command (for best fit), not XYZ." & _ (Chr(13)) & _ "You will be prompted to select an Axis System and a Face belonging to the object you wish to bound." & _ (Chr(13)) & _ (Chr(13)) & _ " - The active document must be a CATPart" & _ (Chr(13)) & _ " - The Axis System must be previously created" & _ (Chr(13)) & _ "" & (Chr(13)) & _ " Are you ready to continue?") Style = vbYesNo 'Define buttons. If MsgBox(Message, Style) = vbYes Then 'Declare variables Dim axis Dim remake Dim partDocument1 As PartDocument Dim part1 As Part Dim axisref As Object Dim shapeFactory1 As ShapeFactory Dim hybridShapeFactory1 As hybridShapeFactory Dim sStatus As String Dim hybridShapeD1, hybridShapeD2, hybridShapeD3 As HybridShapeDirection Dim Default, a1, a2, a3, a4, a5, a6 'To change the offsets of the box Dim bodies1 As Bodies Dim body1 As Body Dim reference1 As Reference Dim HybridShapeExtremum1, HybridShapeExtremum2, HybridShapeExtremum3 As HybridShapeExtremum Dim HybridShapeExtremum4, HybridShapeExtremum5, HybridShapeExtremum6 As HybridShapeExtremum Dim originCoord(2) Dim selection As Object Set partDocument1 = CATIA.ActiveDocument If (InStr(partDocument1.Name, ".CATPart")) <> 0 Then Set part1 = partDocument1.Part Set selection = partDocument1.selection part1.Update Set hybridShapeFactory1 = part1.hybridShapeFactory ReDim sFilter(0) MsgBox "Select the axis to base the bounding on." sFilter(0) = "AxisSystem" sStatus = selection.SelectElement2(sFilter, "Select the axis to base the bounding on.", False) Dim axiscoord(2) Dim axissyst Set axissyst = selection.Item(1).Value Set axisref = selection.Item(1).Value ref_name_systaxis = axissyst.Name axissyst.IsCurrent = 1 axissyst.Name = "BBoxAxis" axname = axissyst.Name Dim originpoint As HybridShapePointCoord axissyst.GetOrigin originCoord Set originpoint = hybridShapeFactory1.AddNewPointCoord(originCoord(0), originCoord(1), originCoord(2)) Set axisref = part1.CreateReferenceFromObject(originpoint) axissyst.GetXAxis axiscoord Set hybridShapeD1 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2)) axissyst.GetYAxis axiscoord Set hybridShapeD2 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2)) axissyst.GetZAxis axiscoord Set hybridShapeD3 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2)) Dim Plane_line_1 As HybridShapeLinePtDir Set Plane_line_1 = hybridShapeFactory1.AddNewLinePtDir(originpoint, hybridShapeD1, 0, 0, False) Dim Plane_line_2 As HybridShapeLinePtDir Set Plane_line_2 = hybridShapeFactory1.AddNewLinePtDir(originpoint, hybridShapeD2, 0, 0, False) selection.Clear Set partDocument1 = CATIA.ActiveDocument Set part1 = partDocument1.Part Dim oBodies As Bodies Set oBodies = part1.Bodies 'J is defined to make unique names for Axis and the Body for the bounding box Dim j As Integer j = oBodies.Count Set bodies1 = part1.Bodies Set body1 = bodies1.add() body1.Name = "Bounding Box." & j Set hybridBodies1 = body1.hybridBodies Set hybridBody1 = hybridBodies1.add hybridBody1.Name = "definition_points" ' Ask for face selection, that belongs to object to boundary ReDim sFilter(0) MsgBox "Select a face that belongs to the solid to be bounded." sFilter(0) = "Face" sStatus = selection.SelectElement2(sFilter, "Select a face that belongs to the solid to be bounded.", False) If (sStatus = "Cancel") Then Exit Sub End If Set reference1 = selection.Item(1).Value Dim hybridShapeExtract1 As HybridShapeExtract Set hybridShapeExtract1 = hybridShapeFactory1.AddNewExtract(reference1) hybridShapeExtract1.PropagationType = 1 hybridShapeExtract1.ComplementaryExtract = False hybridShapeExtract1.IsFederated = False Set reference1 = hybridShapeExtract1 'Create the 6 Extrenum items for the Solid/Surf. May not be single points, will be solved with next points Set HybridShapeExtremum1 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD1, 1) Set HybridShapeExtremum2 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD1, 0) Set HybridShapeExtremum3 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD2, 1) Set HybridShapeExtremum4 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD2, 0) Set HybridShapeExtremum5 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD3, 1) Set HybridShapeExtremum6 = hybridShapeFactory1.AddNewExtremum(reference1, hybridShapeD3, 0) part1.Update ' Creates Geometrical Set under the Solid, to contain the construction elements Dim hybridBody2 As hybridbody Set hybridBody2 = hybridBodies1.Item("definition_points") hybridBody2.AppendHybridShape HybridShapeExtremum1 part1.InWorkObject = HybridShapeExtremum1 HybridShapeExtremum1.Name = "max_X" hybridBody2.AppendHybridShape HybridShapeExtremum2 part1.InWorkObject = HybridShapeExtremum2 HybridShapeExtremum2.Name = "min_X" hybridBody2.AppendHybridShape HybridShapeExtremum3 part1.InWorkObject = HybridShapeExtremum3 HybridShapeExtremum3.Name = "max_Y" hybridBody2.AppendHybridShape HybridShapeExtremum4 part1.InWorkObject = HybridShapeExtremum4 HybridShapeExtremum4.Name = "min_Y" hybridBody2.AppendHybridShape HybridShapeExtremum5 part1.InWorkObject = HybridShapeExtremum5 HybridShapeExtremum5.Name = "max_Z" hybridBody2.AppendHybridShape HybridShapeExtremum6 part1.InWorkObject = HybridShapeExtremum6 HybridShapeExtremum6.Name = "min_Z" part1.Update ' Creates a 6 single points using the Extrenums as refs, so if the Extrenum was a line or surf, you can still offset planes to these points Dim Ref1 As Reference Set Ref1 = part1.CreateReferenceFromObject(HybridShapeExtremum1) Dim Point1 As HybridShapePointCoord Set Point1 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref1) hybridBody2.AppendHybridShape Point1 Set point_ref11 = part1.CreateReferenceFromObject(Point1) Dim Ref2 As Reference Set Ref2 = part1.CreateReferenceFromObject(HybridShapeExtremum2) Dim Point2 As HybridShapePointCoord Set Point2 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref2) hybridBody2.AppendHybridShape Point2 Set point_ref12 = part1.CreateReferenceFromObject(Point2) Dim Ref3 As Reference Set Ref3 = part1.CreateReferenceFromObject(HybridShapeExtremum3) Dim Point3 As HybridShapePointCoord Set Point3 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref3) hybridBody2.AppendHybridShape Point3 Set point_ref13 = part1.CreateReferenceFromObject(Point3) Dim Ref4 As Reference Set Ref4 = part1.CreateReferenceFromObject(HybridShapeExtremum4) Dim Point4 As HybridShapePointCoord Set Point4 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref4) hybridBody2.AppendHybridShape Point4 Set point_ref14 = part1.CreateReferenceFromObject(Point4) Dim Ref5 As Reference Set Ref5 = part1.CreateReferenceFromObject(HybridShapeExtremum5) Dim Point5 As HybridShapePointCoord Set Point5 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref5) hybridBody2.AppendHybridShape Point5 Set point_ref5 = part1.CreateReferenceFromObject(Point5) Dim Ref6 As Reference Set Ref6 = part1.CreateReferenceFromObject(HybridShapeExtremum6) Dim Point6 As HybridShapePointCoord Set Point6 = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, Ref6) hybridBody2.AppendHybridShape Point6 Set point_ref6 = part1.CreateReferenceFromObject(Point6) part1.Update axissyst.IsCurrent = 1 'Create a sketch, will the the X and Y boundary Set sketches1 = hybridBody1.HybridSketches Set reference_axis_syst = part1.CreateReferenceFromName("Selection_RSur:(Face:(Brp:(BBoxAxis;1);None:());BBoxAxis)") Set standard_body_sketch1 = sketches1.add(reference_axis_syst) Set factory2D1 = standard_body_sketch1.OpenEdition() Set geometricElements1 = standard_body_sketch1.GeometricElements Set axis2D1 = geometricElements1.Item("AbsoluteAxis") Set line_HDirection = axis2D1.GetItem("HDirection") line_HDirection.ReportName = 1 Set line_VDirection = axis2D1.GetItem("VDirection") line_VDirection.ReportName = 2 ' Creates a square in the sketch ponto = 20000 Set point_ref_1 = factory2D1.CreatePoint(-ponto, -ponto) point_ref_1.ReportName = 3 Set point_ref_2 = factory2D1.CreatePoint(ponto, -ponto) point_ref_2.ReportName = 4 Set point_ref_3 = factory2D1.CreatePoint(ponto, ponto) point_ref_3.ReportName = 5 Set point_ref_4 = factory2D1.CreatePoint(-ponto, ponto) point_ref_4.ReportName = 6 Set line_ref_1_2 = factory2D1.CreateLine(-ponto, -ponto, ponto, -ponto) line_ref_1_2.ReportName = 7 line_ref_1_2.StartPoint = point_ref_1 line_ref_1_2.EndPoint = point_ref_2 Set line_ref_2_3 = factory2D1.CreateLine(ponto, -ponto, ponto, ponto) line_ref_2_3.ReportName = 8 line_ref_2_3.StartPoint = point_ref_2 line_ref_2_3.EndPoint = point_ref_3 Set line_ref_3_4 = factory2D1.CreateLine(-ponto, ponto, ponto, ponto) line_ref_3_4.ReportName = 9 line_ref_3_4.StartPoint = point_ref_4 line_ref_3_4.EndPoint = point_ref_3 Set line_ref_4_1 = factory2D1.CreateLine(-ponto, -ponto, -ponto, ponto) line_ref_4_1.ReportName = 10 'line_ref_4_1.Construction = True line_ref_4_1.StartPoint = point_ref_1 line_ref_4_1.EndPoint = point_ref_4 ' Create Reference lines and constraints Set reference_line_ref_1_2 = part1.CreateReferenceFromObject(line_ref_1_2) Set reference_line_ref_2_3 = part1.CreateReferenceFromObject(line_ref_2_3) Set reference_line_ref_3_4 = part1.CreateReferenceFromObject(line_ref_3_4) Set reference_line_ref_4_1 = part1.CreateReferenceFromObject(line_ref_4_1) Set electrode_constraints = standard_body_sketch1.Constraints Set constraint_toto_2 = electrode_constraints.AddBiEltCst(catCstTypeDistance, point_ref11, reference_line_ref_2_3) Set constraint_toto_3 = electrode_constraints.AddBiEltCst(catCstTypeDistance, point_ref13, reference_line_ref_3_4) Set constraint_toto_4 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref_4_1, point_ref12) Set constraint_toto_1 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref_1_2, point_ref14) Dim length1 As Dimension Set length1 = constraint_toto_1.Dimension length1.Value = 0 Dim length2 As Dimension Set length2 = constraint_toto_2.Dimension length2.Value = 0 Dim length3 As Dimension Set length3 = constraint_toto_3.Dimension length3.Value = 0 Dim length4 As Dimension Set length4 = constraint_toto_4.Dimension length4.Value = 0 standard_body_sketch1.CloseEdition part1.Update '---------------------------------------------------------------------------------------------------------------------------------- ' Creation of the Max Z and Min Z planes '---------------------------------------------------------------------------------------------------------------------------------- Dim plan_inferieur As HybridShapePlaneOffsetPt Dim plan_origin As HybridShapePlane2Lines Dim Origin_line_1 As Reference Set Origin_line_1 = part1.CreateReferenceFromObject(line_HDirection) Dim Origin_line_2 As Reference Set Origin_line_2 = part1.CreateReferenceFromObject(line_VDirection) Set plan_origin = hybridShapeFactory1.AddNewPlane2Lines(Origin_line_1, Origin_line_2) Dim ref_plan_origin As Reference Set ref_plan_origin = part1.CreateReferenceFromObject(plan_origin) Set Ref6 = part1.CreateReferenceFromObject(HybridShapeExtremum6) Set plan_inferieur = hybridShapeFactory1.AddNewPlaneOffsetPt(ref_plan_origin, point_ref6) hybridBody2.AppendHybridShape plan_inferieur part1.InWorkObject = plan_inferieur Dim plan_superieur As HybridShapePlaneOffsetPt Set Ref5 = part1.CreateReferenceFromObject(HybridShapeExtremum5) Set plan_superieur = hybridShapeFactory1.AddNewPlaneOffsetPt(ref_plan_origin, point_ref5) hybridBody2.AppendHybridShape plan_superieur part1.InWorkObject = plan_superieur part1.Update '---------------------------------------------------------------------------------------------------------------------------------- ' Creates the line that sweeps around the XY Sketch boundary '---------------------------------------------------------------------------------------------------------------------------------- Dim Point_inf As HybridShapePointCoord Set Point_inf = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, point_ref6) hybridBody2.AppendHybridShape Point_inf Dim ref_point_inf As Reference Set ref_point_inf = part1.CreateReferenceFromObject(Point_inf) Dim proj_pt_inf As HybridShapeProject Set proj_pt_inf = hybridShapeFactory1.AddNewProject(point_ref6, plan_superieur) hybridBody2.AppendHybridShape proj_pt_inf part1.InWorkObject = proj_pt_inf Dim Point_sup As HybridShapePointCoord Set Point_sup = hybridShapeFactory1.AddNewPointCoordWithReference(0, 0, 0, proj_pt_inf) hybridBody2.AppendHybridShape Point_sup Dim ref_point_sup As Reference Set ref_point_sup = part1.CreateReferenceFromObject(Point_sup) Dim line_guide As HybridShapeLinePtPt Set line_guide = hybridShapeFactory1.AddNewLinePtPt(ref_point_sup, ref_point_inf) hybridBody2.AppendHybridShape line_guide part1.InWorkObject = line_guide Set ref_guideline = part1.CreateReferenceFromObject(line_guide) Dim oStart As Length Set oStart = line_guide.BeginOffset oStart.Value = 1 Dim oEnd As Length Set oEnd = line_guide.EndOffset oEnd.Value = 1 Set constraints_for_z = part1.Constraints Set constraint_dz = constraints_for_z.AddMonoEltCst(catCstTypeLength, ref_guideline) Set length_dz = constraint_dz.Dimension part1.Update '---------------------------------------------------------------------------------------------------------------------------------- ' Second Sketch, basically the XY boundary sketch placed down to Min Z '---------------------------------------------------------------------------------------------------------------------------------- Set sketches2 = hybridBody1.HybridSketches Set standard_body_sketch2 = sketches2.add(plan_inferieur) Set factory2D2 = standard_body_sketch2.OpenEdition() Set geometricElements2 = standard_body_sketch2.GeometricElements Set axis2D1 = geometricElements1.Item("AbsoluteAxis") pont = 200000 Set point_ref1_1 = factory2D2.CreatePoint(-pont, -pont) Set point_ref1_2 = factory2D2.CreatePoint(pont, -pont) Set point_ref1_3 = factory2D2.CreatePoint(pont, pont) Set point_ref1_4 = factory2D2.CreatePoint(-pont, pont) Set line_ref1_1_2 = factory2D2.CreateLine(-pont, -pont, pont, -pont) line_ref1_1_2.StartPoint = point_ref1_1 line_ref1_1_2.EndPoint = point_ref1_2 Set line_ref1_2_3 = factory2D2.CreateLine(pont, -pont, pont, pont) line_ref1_2_3.StartPoint = point_ref1_2 line_ref1_2_3.EndPoint = point_ref1_3 Set line_ref1_3_4 = factory2D2.CreateLine(-pont, pont, pont, pont) line_ref1_3_4.StartPoint = point_ref1_4 line_ref1_3_4.EndPoint = point_ref1_3 Set line_ref1_4_1 = factory2D2.CreateLine(-pont, -pont, -pont, pont) line_ref1_4_1.StartPoint = point_ref1_1 line_ref1_4_1.EndPoint = point_ref1_4 Set reference_line_ref1_1_2 = part1.CreateReferenceFromObject(line_ref1_1_2) Set reference_line_ref1_2_3 = part1.CreateReferenceFromObject(line_ref1_2_3) Set reference_line_ref1_3_4 = part1.CreateReferenceFromObject(line_ref1_3_4) Set reference_line_ref1_4_1 = part1.CreateReferenceFromObject(line_ref1_4_1) Set reference_line_ref_1_2 = part1.CreateReferenceFromObject(line_ref_1_2) Set reference_line_ref_2_3 = part1.CreateReferenceFromObject(line_ref_2_3) Set reference_line_ref_3_4 = part1.CreateReferenceFromObject(line_ref_3_4) Set reference_line_ref_4_1 = part1.CreateReferenceFromObject(line_ref_4_1) Set proj_1_2 = factory2D2.CreateProjection(reference_line_ref_1_2) Set proj_2_3 = factory2D2.CreateProjection(reference_line_ref_2_3) Set proj_3_4 = factory2D2.CreateProjection(reference_line_ref_3_4) Set proj_4_1 = factory2D2.CreateProjection(reference_line_ref_4_1) Set ref_line_sk1_1_2 = part1.CreateReferenceFromObject(proj_1_2) Set ref_line_sk1_2_3 = part1.CreateReferenceFromObject(proj_2_3) Set ref_line_sk1_3_4 = part1.CreateReferenceFromObject(proj_3_4) Set ref_line_sk1_4_1 = part1.CreateReferenceFromObject(proj_4_1) Set electrode_constraints = standard_body_sketch2.Constraints Set constraint_toto_11 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref1_1_2, ref_line_sk1_1_2) Set constraint_toto_12 = electrode_constraints.AddBiEltCst(catCstTypeDistance, ref_line_sk1_2_3, reference_line_ref1_2_3) Set constraint_toto_13 = electrode_constraints.AddBiEltCst(catCstTypeDistance, ref_line_sk1_3_4, reference_line_ref1_3_4) Set constraint_toto_14 = electrode_constraints.AddBiEltCst(catCstTypeDistance, reference_line_ref1_4_1, ref_line_sk1_4_1) 'Dim length11 As Dimension Set length11 = constraint_toto_11.Dimension length11.Value = 1 Dim length12 As Dimension Set length12 = constraint_toto_12.Dimension length12.Value = 1 Dim length13 As Dimension Set length13 = constraint_toto_13.Dimension length13.Value = 1 Dim length14 As Dimension Set length14 = constraint_toto_14.Dimension length14.Value = 1 standard_body_sketch2.CloseEdition part1.Update '---------------------------------------------------------------------------------------------------------------------------------- ' Offset from Sketch2, using the Relations so you can change the offsets '---------------------------------------------------------------------------------------------------------------------------------- Set sketches3 = hybridBody1.HybridSketches Set standard_body_sketch3 = sketches3.add(plan_inferieur) Set factory2D3 = standard_body_sketch3.OpenEdition() Set geometricElements3 = standard_body_sketch3.GeometricElements Set axis2D1 = geometricElements1.Item("AbsoluteAxis") Set reference_line_ref1_1_2 = part1.CreateReferenceFromObject(line_ref1_1_2) Set reference_line_ref1_2_3 = part1.CreateReferenceFromObject(line_ref1_2_3) Set reference_line_ref1_3_4 = part1.CreateReferenceFromObject(line_ref1_3_4) Set reference_line_ref1_4_1 = part1.CreateReferenceFromObject(line_ref1_4_1) Set proj1_1_2 = factory2D3.CreateProjection(reference_line_ref1_1_2) Set proj1_2_3 = factory2D3.CreateProjection(reference_line_ref1_2_3) Set proj1_3_4 = factory2D3.CreateProjection(reference_line_ref1_3_4) Set proj1_4_1 = factory2D3.CreateProjection(reference_line_ref1_4_1) Set ref_proj1_1_2 = part1.CreateReferenceFromObject(proj1_1_2) Set ref_proj1_2_3 = part1.CreateReferenceFromObject(proj1_2_3) Set ref_proj1_3_4 = part1.CreateReferenceFromObject(proj1_3_4) Set ref_proj1_4_1 = part1.CreateReferenceFromObject(proj1_4_1) Set constraints_dim = standard_body_sketch3.Constraints Set constraint_dx = constraints_dim.AddMonoEltCst(catCstTypeLength, ref_proj1_1_2) Set constraint_dy = constraints_dim.AddMonoEltCst(catCstTypeLength, ref_proj1_2_3) Set length_dx = constraint_dx.Dimension dx_value = length_dx.Value Set length_dy = constraint_dy.Dimension dy_value = length_dy.Value standard_body_sketch3.CloseEdition part1.Update ' Create the offset parameters Dim string_1 As String string_1 = "Offset_Bbox_Max_X." & j Dim string_2 As String string_2 = "Offset_Bbox_Min_X." & j Dim string_3 As String string_3 = "Offset_Bbox_Max_Y." & j Dim string_4 As String string_4 = "Offset_Bbox_Min_Y." & j Dim string_5 As String string_5 = "Offset_Bbox_Max_Z." & j Dim string_6 As String string_6 = "Offset_Bbox_Min_Z." & j Dim string_7 As String string_7 = "Bbox_dx." & j Dim string_8 As String string_8 = "Bbox_dy." & j Dim string_9 As String string_9 = "Bbox_dz." & j Dim Offset_Bbox_Max_X As RealParam Set Offset_Bbox_Max_X = part1.Parameters.CreateDimension(string_1, "Length", 0) Dim Offset_Bbox_Min_X As RealParam Set Offset_Bbox_Min_X = part1.Parameters.CreateDimension(string_2, "Length", 0) Dim Offset_Bbox_Max_Y As RealParam Set Offset_Bbox_Max_Y = part1.Parameters.CreateDimension(string_3, "Length", 0) Dim Offset_Bbox_Min_Y As RealParam Set Offset_Bbox_Min_Y = part1.Parameters.CreateDimension(string_4, "Length", 0) Dim Offset_Bbox_Max_Z As RealParam Set Offset_Bbox_Max_Z = part1.Parameters.CreateDimension(string_5, "Length", 0) Dim Offset_Bbox_Min_Z As RealParam Set Offset_Bbox_Min_Z = part1.Parameters.CreateDimension(string_6, "Length", 0) Set Bbox_dx_hidden = part1.Parameters.CreateDimension(string_7, "Length", dx_value) Set Bbox_dy_hidden = part1.Parameters.CreateDimension(string_8, "Length", dy_value) Set Bbox_dz_hidden = part1.Parameters.CreateDimension(string_9, "Length", length_dz.Value) Bbox_dx_hidden.Hidden = True Bbox_dy_hidden.Hidden = True Bbox_dz_hidden.Hidden = True Set Bbox_dx = part1.Parameters.CreateDimension(string_7, "Length", 0) Set Bbox_dy = part1.Parameters.CreateDimension(string_8, "Length", 0) Set Bbox_dz = part1.Parameters.CreateDimension(string_9, "Length", 0) Dim Formula_1 As Formula Set Formula_1 = part1.Relations.CreateFormula("formula_Bbox_1." & j, "", length14, "Offset_Bbox_Min_X." & j) Dim Formula_2 As Formula Set Formula_2 = part1.Relations.CreateFormula("formula_Bbox_2." & j, "", length12, "Offset_Bbox_Max_X." & j) Dim Formula_3 As Formula Set Formula_3 = part1.Relations.CreateFormula("formula_Bbox_4." & j, "", length11, "Offset_Bbox_Min_Y." & j) Dim Formula_4 As Formula Set Formula_4 = part1.Relations.CreateFormula("formula_Bbox_4." & j, "", length13, "Offset_Bbox_Max_Y." & j) Dim Formula_5 As Formula Set Formula_5 = part1.Relations.CreateFormula("formula_Bbox_5." & j, "", oEnd, " Offset_Bbox_Min_Z." & j) Dim Formula_6 As Formula Set Formula_6 = part1.Relations.CreateFormula("formula_Bbox_6." & j, "", oStart, " Offset_Bbox_Max_Z." & j) Dim Formula_7 As Formula Set Formula_7 = part1.Relations.CreateFormula("formula_Bbox_7." & j, "", Bbox_dx, "Bbox_dx." & j & "+Offset_Bbox_Min_X." & j & "+Offset_Bbox_Max_X." & j & "-2mm") Dim Formula_8 As Formula Set Formula_8 = part1.Relations.CreateFormula("formula_Bbox_8." & j, "", Bbox_dy, "Bbox_dy." & j & "+Offset_Bbox_Min_Y." & j & "+Offset_Bbox_Max_Y." & j & "-2mm") Dim Formula_9 As Formula Set Formula_9 = part1.Relations.CreateFormula("formula_Bbox_9." & j, "", Bbox_dz, "Bbox_dz." & j & "+Offset_Bbox_Min_Z." & j & "+Offset_Bbox_Max_Z." & j & "-2mm") '---------------------------------------------------------------------------------------------------------------------------------- ' Sweep the Z line around the XY boundary. This will be closed '---------------------------------------------------------------------------------------------------------------------------------- Set sweepref_1 = part1.CreateReferenceFromObject(standard_body_sketch3) Set guide1 = part1.CreateReferenceFromObject(line_guide) Dim sweep1 As HybridShapeSweepExplicit Set sweep1 = hybridShapeFactory1.AddNewSweepExplicit(sweepref_1, guide1) hybridBody2.AppendHybridShape sweep1 part1.InWorkObject = sweep1 part1.Update ' Close the Sweep Set shapeFactory1 = part1.ShapeFactory Set hybridBodies1 = body1.hybridBodies Set hybridBody1 = hybridBodies1.Item("definition_points") Dim hybridShapes1 As HybridShapes Set hybridShapes1 = hybridBody1.HybridShapes Dim refer1 As Reference Set refer1 = part1.CreateReferenceFromObject(sweep1) Dim closeSurface1 As CloseSurface Set closeSurface1 = shapeFactory1.AddNewCloseSurface(refer1) closeSurface1.Name = "BoundingBox" part1.Update selection.Clear selection.add hybridBody1 selection.VisProperties.SetShow catVisPropertyNoShowAttr selection.Clear selection.add body1 selection.VisProperties.SetRealColor 0, 0, 0, 0 selection.VisProperties.SetRealOpacity 150, 1 selection.VisProperties.SetRealWidth 2, 1 part1.Update axissyst.Name = "Bounding Box Axis." & j Else MsgBox "The active document must be a CATPart" End If End If End Sub
