Does anyone have thermal properties
Does anyone have thermal properties for an alloy referred to as Stoody Alloy #2?  I've canvassed the internet but keep coming up empty on properties such as thermal conductivity and specific heat.  I've calculated these properties based on a simple constituent relation (i.e., based on percent composition by weight).  I also have a technical data sheet from (I think) the Aerospace Material Handbook, but it does not include these properties.  Thanks in advance for your help.
RE: Does anyone have thermal properties
Try the Stoody company, last I heard, they were in Bowling Green Kentucky.  Good Luck!
Thanks very much for the info and link.  I ended up registering at the following link:
http://www.stellite.com
where I found limited thermal properties for Stoody #2.  Thanks again!
