Air trap in epdm rubber compound
Hi guys,
Currently i am having a problem with my epdm compound formula, the problem is that there are many air traps / blisters on the surface of the calendared blank sheet.
Here are the formula below:
Vistalon 7001 100 phr
Clays 325 mesh 140 phr
Calcium carbonate 400 mesh 230 phr
N-330 Carbon black 30 phr
Parrafinic oil 30 phi
I have also tried to put 5 phr of calcium oxide but it didn't work... any suggestions ? thanks before :)
RE: Air trap in epdm rubber compound
Good Luck!
