Compressibility Charts
I understand how to use them but my book gives very exact answers that I feel I could only estimate. Is there a formula used when your P(reduced) and T(reduced) aren't nice numbers to work with?
For example a Pr of .977 and a Tr of 1.038. My compressibility chart has a large gap between Tr of 1 and 1.05 in that region so I don't know how the book got an answer of Z=.56
RE: Compressibility Charts
You can calculate an estimate for the compressibility factor using the appropriate Equation of State. Calculating to a higher precision does not automatically make the answer more accurate.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
@25362
That is the same graph that i use. I understand how you could estimate the Pr easily but not the Tr because they are curves.
Katmar is absolutely right.
The article gives an example and clearly says Tr was interpolated.
As Pr approaches 1.0, Tr approaches 1.0, the error in predicting z increases to about 30% according to the narrative in Perry, which is probably why the graph stops in this area. If you need some ballpark values on this through a numerical expression, you could try using the Redlich Kwong EOS or other similar EOSs; which you can find in physical chem uni textbooks or chem engg texts ( else Perry Chem Engg Handbook also gives you a few methods on this).
