Slow Saves/Large File/Huge PDF files
I have a weldment with 55 parts. It Is comprised of approx. 95% imported IGES part files from old Mechanical Desktop models. The assembly file is 58mb, and saves are long and can't functionally create PDF or plot the file.
Suggestions?
Suggestions?
NX 8.0.3.4
RE: Slow Saves/Large File/Huge PDF files
File -> Export -> Heal Geometry...
...which will create copies of the original files but with all topological 'imperfections' removed. This should help reduce the size of the part files and give you a cleaner set of files.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX 8.0.3.4
Unfortunately, saves are taking 3 or 4 minutes on the weldment and PDF creation yields "Very Large Plot File Detected! Use PDF Export Program Instead" after long wait. PDF Export created a 23 mb file.
Any additional suggestions?
NX 8.0.3.4
Can you import using STEP instead ?
The geometry quality is far better. ( smaller files, quicker interaction.)
John mentioned the Heal Geometry, have you run that on all files ?
Tomas
NX 8.0.3.4
