the steps to follow for numerical modeling
good day everyone
i have a mathematical model in form of equations to calculate the fracture energy,
what are the steps to follow to use these equations in abaqus in order to do a numerical modeling of my problem.
Best regards
Best regards
RE: the steps to follow for numerical modeling
Model what? You can have a crack in pretty much anything.
Yes, i have a notched specimen(CT or SENT), and i have to determine rhe energy parameter J when dealing with fracture of a plastic material. The energy parameter J is expressed in a form of equation in which a geometrical parameter and the crack length.
so, what are the steps to follow to determine numerically this parameter.
thanks for your help.
Abaqus is capable of simulating monotonic crack propagation via a method known as XFEM, again I suggest working through the tutorials.
or it exists Handy in abaqus.
thanks sir.
It maybe that your particular material is not covered in Abaqus & you will have to write your own subroutine but the only way you will know that is to read the documentation & work through the tutorials.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
