Analysis of Surcharge on Concrete Wall
Hello All,
I need to analyze how a large surcharge will act on a 6'-8" tall poured concrete wall with a slab on the top (analyzed as a basement wall). The surcharge comes from a silo that will be resting on the concrete slab. The weight of the silo divided by its area gives a 2,044 psf surcharge. To calculate the pressure that this puts on the wall, I think I should just take (at rest earth pressure coefficient)x(surcharge)x(height of wall) and apply that load at mid-height of the wall. Does this sound accurate?
RE: Analysis of Surcharge on Concrete Wall
