ABAQUS: How to define adiabatic interfaces in a heat transfer simulation
I want to perform a heat transfer calculation of a simple model. Basically I have one Part which contains two concentric disks where the outer disk is split into "chunks" (see picture below, also attached). I have a surface heat flux load applied in the inner face of the inner ring and I apply convection to the outer faces of the outer ring (different heat transfer coefficients). My problem is how to make the interfaces between the "chunks" adiabatic.
Any ideas?
Many thanks!
Any ideas?
Many thanks!
RE: ABAQUS: How to define adiabatic interfaces in a heat transfer simulation
https://res.cloudinary.com/engineering-com/image/upload/v1444737003/tips/conductivityIssue_vvzevg.tiff
This can be achieved by specifying a very small conduction coefficient.
