How to open a *.CATPart from *.zip?
I've tried to open a *.zip file from http://site.voila.fr/catia_tutorial (Telechargement)....
Please advise the correct steps.
Thanks!
Attitude is everything!
RE: How to open a *.CATPart from *.zip?
First you have to unzip the *.zip file in a temporary folder. After that you can open with CATIA.
Zip is the extension for a software which make an archive for different files (doesn't metter how big they are).
You can download an evalution copy from www.winzip.com
Fernando
Hi DannyNC,
if you use the unix system, you can used the gzip command.
its a freeware, look at the site : http://sunfreeware.com
Best regards.
Pascal (I'm French)
but beginner in English language
plambert@rgb-technologie.fr
I'm using V5R6, and after unzipped & saved the *.CATPart file, and opened Catia, I tried to OPEN the file saved already, but CATIA closed itself.
...the *.zip done with V5R6 (see...Telechargement)
...if I double click on the *.CATPart file, Catia try to open and again disappear ...
Thanks for help and your time,
Daniel
Hi DannyNC,
it's a bizarre problem !
you can delete your CATSettings and retry !
You know the version of files in question ?
It would not be a problem of date of files with regard to the date of the machine ?
else I don't see !
have fun ...
Pascal (I'm French)
