Question about straightness of a planar surface
I am a new one. I have a question for you guys.
Question: Is the straightness of a considered planar surface (usually no modifier indicated) used under the regardless of feature size (RFS) concept?
For example, please see the Fig.5-6 Specifying a straightness of a flat surface in ASME Y14.5 2009.
The straightness for a planar surface rather than derived median line or derived median plane never uses MMC or LMC modifiers. And RFS concept is implied for all geometric tolerances where no modifier is specified. So the straightness of a planar surface mostly like to be under the RFS condition.
Is it correct or not?
RE: Question about straightness of a planar surface
When dealing with surfaces, there really is no such thing as MMC or LMC. So I suppose it's legal to speak about a surface tolerance "RFS" but it doesn't really add any value since surfaces have no size, as Dave mentioned.
John-Paul Belanger
Geometric Learning Systems
Talking about FOS, how should we consider this part which is displayed as attached file as below?
Should we treat the part as one that has FOS or partial FOS?
John Acosta, GDTP Senior Level
Manufacturing Engineering Tech
SSG, U.S. Army
Taji, Iraq OIF II
Personally I believe that the first priority is to solve the problem whether or not using RFS concept in this case.
Talking about partial FOS, there is not authorized standard statement on it. But most cases in Y14.5, you will see no perfect opposite sides of those parts. Such as Fig. 5-7, Fig. 6-2, and so on.
Sorry for jump a little bit into the conversation, but I am not sure how we can help if we don’t know what are the functional requirements.
The standard allows you to use both (MMC or RFS) depending of the functional requirements/ design intent.
SSG, U.S. Army
Taji, Iraq OIF II
What is this? I am a little bit confused now.
So what do you think the answer to the question is?
SSG, U.S. Army
Taji, Iraq OIF II
MQSCI651
Did you read the thread CH pointed to?
If yes, did you see what is the answer?
SSG, U.S. Army
Taji, Iraq OIF II
SSG, U.S. Army
Taji, Iraq OIF II
There are two kinds of tolerances, size tolerance and geometric tolerance. Straightness and flatness are geometric tolerances.
No, that is incorrect. In this case, the worst case is dependent on the size. As CH pointed out, RFS means Regardless of Feature Size so it absolutely has to do with the size of the feature.
SSG, U.S. Army
Taji, Iraq OIF II
My current understanding is still that the geometric tolerance is not relative to size tolerance in this case. They are individual each other. RFS = no matter what feature size is, geometric tolerance should be kept in a certain level. There are only two choices, the worst one is 0.2.
Please help me to point out what's wrong with my opinion.
"tolerance, geometric: the general term applied to the category
of tolerances used to control size, form, profile,
orientation, location, and runout."
What most do is read between the lines and fill in the word 'symbol' for the word tolerance in that definition. It would be nice if the Committee had managed to actually change the definition, but they either overlooked it, or something.
Anyway, a size tolerance does control size, and often form and sometimes profile. Just not explicitly, but that's another word that isn't in the definition.
General rule #1 directly relates size tolerance to form tolerance. If you don't know about general rule #1 then maybe that's the disconnect. If you do know about it then maybe we need to understand it better. Basically general rule #1 says that as the size of a feature departs MMC towards LMC, that much deviation in form is allowed. At MMC, the form must be perfect. So in your case 30.3 would be the MMC size. At this size, the form must be perfect. Straightness is a form tolerance so at 30.3 the straightness error must be 0. If the feature were to actually measure 30.2 then the allowable straightness error would be 0.1 because 30.2 is 0.1 away from the MMC size. There are some exceptions to rule #1 and one of them has to do with straightness but this is not that case so there is no exception here.
My biggest concern with this exercise is with what is meant by "worst case." Do you know who authored the material? Also what version if the standard is the material teaching? 1994 or 2009?
SSG, U.S. Army
Taji, Iraq OIF II
SSG, U.S. Army
Taji, Iraq OIF II
Rule#1 and where is applicable and where is not.
Don't reinvent the wheel. Read the previous thread (the entire thread not just portions of it) and agree or disagree with the statements presented there.
Hi powerhound, I read this problem from the other forum. I agree with what you said about this. My direct feeling is different resource has different background, and different language. I don't know who authored this material. I don't know what does the "worst case" mean under what kind of background. In the other words, when we say the "worst case", what will be based on?
