can earthing be made in basement ?
Hi engineers i need some help
we have this building being constructed and i have been asked if we can install the earthing rods under the basement and not outside the building. Can it be done ? Or is it against the code ?
RE: can earthing be made in basement ?
But again, this is not the place to ask.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Check with your local AHJ (Authority Having Jurisdiction.)
Bill
"Why not the best?"
Jimmy Carter
But Wiki says:
Yours
Bill
"Why not the best?"
Jimmy Carter
At one time it was the duty of the meter reader to look at the customer instalation to see if they could see any problems, such as a loose ground connection onto the ground rod.
By placing the grounding connection in a basement, it makes it difficult to inspect, and the likely hood is it won't be inspected.
I love these moments of nostalgia, meter readers.
